** CHUG'S PAYDAY DEALS - IT'S A SPRING CLEANOUT! **
OcUK Staff
26 Nov 2014
Stoke
So, I've got some extra special deals for you here, some of this stuff is end of line, so expect big savings, others are products that have never been so low in price! These prices will be live till late Tuesday, so you have 4 days!
BitFenix Colossus Blue & Red LED Big Tower Case - Black @ £109.99 inc VAT
Introducing BitFenix Colossus – the PC chassis for the uncompromising enthusiast. Offering unmatched expandability, security, and cooling all wrapped up in a modern and elegant body, Colossus represents months of intensive research, product development, and meticulous design. The result is a chassis like no other; a chassis that serves as an ideal enclosure for the most colossal gaming rigs.
Ready for the Future
The next generation of USB connectivity is here. Equipped with two USB 3.0 ports, Colossus allows you to connect an ever-growing number of USB 3.0 devices and experience data transfer speeds up to ten times that of USB 2.0. With USB 3.0 already built-in, Colossus can last you several upgrades, further future-proofing your system.
At Your Command
Designed to be the center of your digital domain, Colossus puts you in command with a PWM fan controller and multimode light controls. Tune your fans down for silence or up for extra cooling. Select your desired lighting color or turn them off completely. With Colossus, control is always at your fingertips.
Advanced LED Lighting System
Perhaps the most striking feature of Colossus at first glance is the advanced LED lighting system. Not only is the light evenly distributed for a truly inspired look, but the LED colour is also dual-mode, which means that users can switch between red and blue lighting with the touch of a button.
Unmatched Security with BitFenix S3
Colossus introduces a BitFenix exclusive – S3. S3 is a storage compartment and security system in one. Place your iPhone, hard disk, or other valuables in S3 and lock them away for safe keeping. S3 will even lock down peripherals like USB mice and keyboards plugged into it, and secure everything under lock and key. Simple, safe and secure – that’s BitFenix S3.
Complete Cable Management
Messy cables not only look bad, but they can also restrict airflow in a chassis. That’s why Colossus is designed to manage cables both inside and out. Keep cables from cluttering the inside of the chassis with Colossus' strategically-placed cable holes. Prevent cables from getting caught in opening optical drives with the unique cable-holding front bezel.
Epic Expandability
Colossus gives you the space to build your own supercomputer. Capable of accommodating eight PCI express devices and seven 2.5" SSDs or seven 3.5" hard disk drives, Colossus is ready for multiple upgrades – perfect for a rig of epic proportions.
Massive Cooling
When the action heats up, your system needs to keep its cool. Colossus can be outfitted with up to two 230mm fans, three 140mm fans, or three 120mm fans, meaning huge cooling potential for all system components.
Easy Installation
Big doesn't have to mean unwieldy. Featuring a motherboard CPU cooler cutout on the motherboard tray, specially-designed motherboard standoffs, and an almost completely tool-free design, getting your system up and running with Colossus is a joy. Large yet welcoming, if Colossus reminds you of a friendly giant, we wouldn’t blame you.
Specifications
- Materials: SECC, ABS
- Color (Int/Ext): Black
- Dimensions (WxHxD): 245 x 558 x 582 mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, E-ATX
- 5.25" Drive Bays: x 5 (1 x external 3.5"; tool-free)
- 3.5" Drive Bays: x 7
- 2.5" Drive Bays: x 7 (using standard 3.5" drive bays)
- Cooling Front: 1 x 230mm included
- Cooling Rear: 1 x 140/120mm (not included)
- Cooling Side Panel: n/a
- Cooling Top: 1 x 230mm included (or 1 x 140/120mm not included)
- Cooling Bottom: 1 x 140/120mm (not included)
- PCI Slots: 8 (tool-free)
- I/O: 2 x USB3.0, 2 x USB2.0, eSATA, Audio
- Power Supply: PS2 ATX (bottom, multi direction)
Was £139.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Lian Li PC-CK101LB mini-ITX case with Motor - Black @ £224.99 inc VAT
The most unique case EVER! The Mini ITX format is normally boring but now Lian Li are revolutionising the market with the ultimate "chugga-chugga-chu-chu" train chassis.
- Dimensions: 185 x 258 x 515 mm (W x H x D)
- Material: Aluminum
- Color: Black
- Weight: 4.1 kg
- Form Factor: Mini-ITX
- Fan: 1x 120 mm (rear)
- Drive Bays:
- 1x 5.25 inch (External Slim Drive)
- 1x 3.5 inch (internal)
- 1x 2.5 inch (internal)
- Power supply (preinstalled): SFX 300W 80Plus
- Expansion slots: no
- I / O Panel:
- 2x USB 3.0
Was £299.99 Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Cooler Master Cosmos SE Mid Tower Case @ £119.99 inc VAT
More aggressive, more furious - a sporty addition to the COSMOS series - the COSMOS SE. It features a classic supercar design with curved aluminum handles. Behind the front mesh panel are two 120mm blue LED fans with a LED on/off function. Liquid cooling is the name of the game. It supports up to 3 radiators at once - 120 & 280 & 360mm (rear/top/front). The expandability is supports up to 8 HDDs/18 SSDs.
- Superior liquid cooling support: 120, 240, 280 and 360mm radiator; supports 3 radiators at once - 120+280+360mm.
- Supports up to 8 fans, including 4 installed fans – two front 120mm blue LED fans with LED on/off control, one top 140mm fan and one rear 120mm fan.
- Dual Super Speed USB 3.0.
- Great expandability with the support of up to 8 HDDs/18 SSDs
- Supports all high-end VGAs up to 395mm/15.5 inches long and CPU coolers up to 175mm/6.9 inches tall.
- Large cable management space - 34mm.
- Multiple removable dust filters (top, front, bottom, side panel) for improved system maintenance.
- Supercar inspired design with aluminum curve handles.
- Dimension (W / H / D): 263.8 x 569.4 x 524.4 mm
- Weight: 10.8 kg
- Material: Polymer, Steel, Aluminium, Mesh front bezel, Rubber
- Motherboard Type: ATX, Micro ATX, Mini-ITX
- 5.25" Drive Bay: 3
- 3.5" Drive Bay: 8
- 2.5" SATA HDD Bay: 18 (16 converted from 3.5'' Bays)
- I/O Panel: USB3.0 x 2, USB 2.0 x 2, Audio In and Out
Fan Bays: Top 120/140mm fan x 1 (installed)
- Front: 120mm Blue LED fan x 2 (Installed with LED on/off) or 140mm(optional)
- Rear: 120mm fan x 1 (installed)
- Side: 120/140mm fan x 1 (optional)
- HDD Cage: 120mm fan x 2 (optional)
- Expansion Slots: 7+2
- CPU Cooler Heigh: 175 mm
- Power Supply Standard ATX PS2
Was £144.95 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
BitFenix Prodigy Mini-ITX Cube Case - Aqua Blue @ £40.99 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
Specifications
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Was £59.99 Inc. VAT
Only £40.99 inc VAT.
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - Black @ £64.99 inc VAT
AEGIS features a beautiful rounded shield-inspired front with the same ICON logo display we use on Pandora, and a sporty fresh design all around. It comes in black, white and 3 vibrant colors (red, blue, yellow) and supports an impressive amount of fans and radiators: up to 8 120mm fans or 5 140mm fans, dual 280 radiators or a 360 and 240 combo.
The 3 tool free storage cages are modular and can be moved around or taken out all together, in which case there is still a hidden 2.5" slot behind the PSU and a "show off" 2.5" slot next to the mainboard tray. Besides some nice dust filters on the top, front and bottom, it comes with a built in fan controller, a stylish PSU cover, a rubber padded pump bracket and last but not least a neat reservoir bracket, that let users attach a reservoir or pump/res combo to a 240 or 360 radiator.
Features
- Bold yet Timeless design - Beautiful smooth lines
- Large top panel to channel airflow and block noise
- Closed front panel with large side vents to block noise
- Programmable Bitfenix ICON™ Display - 2.8” diameter, 240 x 320 colour resolution, Connects to internal USB header.
- Available in black, white and 3 vibrant colours
- Mixed colour internals, not just plain black or white
- Huge Sidepanel Window
- Removable PSU Shroud Cover
- Massive Backplate Access for High-End CPU coolers
- Supports 380mm GPU's
- 5 PCI slots for optimum Dual GPU support
- Removable Toolless 2.5"/3.5" bays
- Up to 220mm PSU support
- Up to 8 fans support
- Integrated Fan Controller
- Magnetic Dust Filters
- Supports up to 360mm radiators
- Comes with bundled reservoir and pump brackets
Specification
- Materials: Steel Alloy, Polymer, Acrylic (window)
- Colours: Black/Black
- Case Dimensions (mm/in): 205 x 470 x 480 (WxHxD) - 7.95 x 18.15 x 18.38 (WxHxD)
- Box Dimensions (mm/in): 255 x 530 x 505 (WxHxD) - 10.03 x 20.86 x 19.88 (WxHxD)
- Box Volume: 2.4 ft³/cuft - 68.25L - 0.068m³
- Case Weight (kg/lbs): 6.7 / 14.8
- Box Weight (kg/lbs): 7.8 / 17.2
- Max Heatsink height (mm/in): 170mm / 6.7
- Max AIO support (push/push pull): 360 / 360
- Max radiator support (push/push pull): 360 (85mm) + 240 (60mm) / 360 (60mm) + 240 (60mm)
- Max VGA length (mm/in): 380mm / 14.9 with HDD cage installed (depends on front radiator configuration)
- Motherboard Micro ATX, Mini-ITX
- ICON™ Display: 2.8" TFT, 240 x 320
- 3.5” Drive slots: 4 (two removable cages with 2 tool less slots each)
- 2.5” Drive slots: 4 (one removable cage with 2 tool less slots each, one slot next to the Mainboard, one slot behind the PSU)
- Max HDD capacity: 40TB (4x 8TB 3.5” + 4x 2TB 2.5”)
- Max SSD capacity: 16TB (8x 2TB 2.5”)
- Fan Controller: 4 fan headers, 3 speeds (12v, 7v, 5v) with 3 indicator LEDs (white)
- Cooling Top: 3x 120mm or 2x140mm – click on dust filter
- Cooling Front: 3x 120mm or 2x140mm – magnetic dust filter
- Cooling Bottom: 1x 120mm – magnetic dust filter
- Cooling Bottom: 1x 120mm (included)
- PCI Slots: 5
- I/O: USB 3.0 x 2, Audio, Mic, Power, Reset, Power LED (white), HDD LED (white)
- PSU: PS2 ATX, up to 220mm in length, intake from case interior or case bottom
- Special Features: ICON™ Display, Fan Controller, PSU cover, Magnetic Dust Filters, Pump bracket, Reservoir Bracket, 2 Removable HDD Cages, 1 removable SSD cage, Tool less HDD and SSD system, Hidden 2.5” slot, 2.5” Show Off slot, Window Sidepanel, Rubber Grommets.
Was £79.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - White @ £64.99 inc VAT
Features
Specification
- Colours: White/Black
- PCI Slots: 5
Was £79.99 Inc. VAT
ORDER NOW
NZXT Source 210 Midi Tower Case - White @ £28.99 inc VAT
Gamers spend approximately £30 per game, buy X number of video game titles per year. You know what it’s like…it adds up very quickly. Sometimes gamers are starving college students, sometimes gamers have girlfriends; the green keeps flying away. NZXT’s Source 210 is here to provide the basic chassis to house your rig. It’s modest and contains the essentials for performance. It’s the chassis you can afford.
The Source Series is NZXT’s chassis line designed to be a starting block for first time builders or a stepping stone for those who want to upgrade their rig later on. Each chassis faithfully serves their purpose as an affordable, memorable part of your system building experience; it may just be a keeper.
- Bottom Mounted PSU – Positioned for the most effective PSU ventilation
- Wire Management Support – 20mm space for a neat and easy build
- Aluminum Textured Panel – Accents the chassis for a clean, modern look and feel
- Dual 120mm Front Intake – Takes advantage of front facing HDD bays for excellent airflow
- Maximum Cooling Potential – Eliminate heat by installing up to seven 120mm fans
- Also fits 2 x 120/140mm fan
- Dimensions: (W x H x D) 195mm x 440mm x 495.5mm
- VGA Clearance Maximum: 230mm w/ hard drive, 330mm w/o hard drive
- CPU Heatsink Support: 160mm
- Front Cooling: 2 X 120mm
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 2 X 120/140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 External 5.25" DRIVE BAYS / 8 Internal 3.5" HDD Drives
- Motherboard Support: ATX, MICRO-ATX
- Front I/O Ports: 1 x Standard Audio/Mic, 2 x USB 2.0
Was £34.99 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
NZXT Phantom 530 Full Tower Gaming Case - Red @ £81.95 inc VAT
The Phantom 530 is an evolution of the original in every respect.
The original Phantom set the standard for unique case design and the 530 carries this tradition onwards.
Featuring new cutting edge design features integrated into a comprehensively overhauled chassis structure, a high end gaming PC is well at home within the Phantom 530
Key Features
Up to 34 mm cable management space
8 expansion slots
235mm wide
Kraken X40 / X60 support
Modular hard drive cages
Discrete SSD mount behind motherboard tray
Steel latches
Single channel, 30W fan controller with integrated fan hub
Fully filtered intakes
20 mm cable management space
7 expansion slots
220mm wide
Case Specs
• Dimensions (WxHxD): 235mm x 572mm x 543mm
• Materials: Steel, Plastic
• Total Weight: 10.5 kg
• Motherboard Support: ITX, Micro-ATX, ATX, EATX (322x272mm)
• External Connections: 1 x Audio / Mic, 2 x USB 3.0
Bays and Expansion
• External 5.25”: 3
• Internal 3.5”: 6
• Internal 2.5”: 1+6
• Expansion Slots: 8
Cooling
• Front: 2x140mm/ 120mm or 1x200mm, (1 x 200mm included)
• Rear: 1x140mm (included) / 120mm
• Bottom: 2x120mm
• Side: 1x140mm
• Top: 2x200mm/ 140mm or 3x120mm
• Interior: 1x120mm/140mm
Clearance
• CPU Cooler 183mm
• VGA Card 282mm (With Cage & Pivot Fan), 310mm (With Cage), 444mm (Without Cage)
• Cable Management 26mm (Lowest Point)/ 34mm (Highest Point)
Was £97.99 Inc. VAT
Only £81.95 inc VAT.
ORDER NOW
In-Win S Frame Midi-Tower USB 3.0 - Black / Gold @ £559.99 inc VAT
In Win has introduced its new LIMITED open-frame chassis with a unique one-piece construction design concept combining unconventional craftsmanship techniques to create an impeccable artistry.
Using laser cutting machine processing to cut 4mm thick aluminum sheet metal into a 2 meter long chassis structure the In Win S-Frame is made using complete one piece metal with CNC polishing processes. The dual anodize procedures not only increased the resistance of the aluminum surface but also features a dual colour Black & Gold presentation to give maximized visual enhancement.
Finally, the main structure of S-Frame was bent through 15 times in order to create every bending angle smooth and seamless. These processes also created a beautiful texture of brushed hairline sliding along S-Frames curves.
S-Frame’s simplistic aesthetics required a selection of delicate techniques to accomplish the uniqueness, strength and perfect artistry enjoyed as the S-Frame becomes available …
Specifications:-
- Material: 4mm Aluminum, Tempered Glass
- Internal Drive Bay 3.5” or 2.5” x 4
- M/B Form Factor ATX / Micro-ATX
- Power Supply ATX12V, PSII and EPS
- Power Supply Mounting Area Length up to 300mm / Height up to 95mm
- I/O Port USB3.0 x 4, HD Audio
- I/O Expansion Slots PCI-E Slot x 8
- Supports High-end Graphic Card
- (Length: up to 340mm, Height: up to 160mm)
- Thermal Solution Supports
- 120mm Bottom Fan x 3
- 360mm Liquid Cooling Radiator(width up to 135mm)
- CPU heatsink up to 195mm
- Dimensions (H x W x D) 560 x 313 x 755mm, 22” x 12.3” x 29.7”
- Net Weight 17.41kg
- Gross Weight 23.2kg
- Our products comply with RoHS regulations
* Specifications may vary based on different regions
Was £646.99 Inc. VAT
Only £559.99 inc VAT.
ORDER NOW
Zalman ZM 1250W '80 Plus Platinum' Modular Power Supply @ £139.99 inc VAT
Thanks to a new design the ZM1250 efficiency of the unit is very high 89-93% (20-100% load) top efficiency. It also uses a powerful and highly reliable DC-DC module (to increase performance and reliability), along with full bridge and LLC resonant circuits which lowers switching losses, boosts efficiency and is guaranteed to deliver 1250w continuous power even in a warm case (up to 50 °C).
The ZM12050-Platinum boasts an ultra-quiet 140 mm fan, the speed of which is controlled by the Smart Fan Control system. This means that the fan won't spin at all until the PSU is under 40% load and this minimises audible noise ensuring the PSU remains as quiet as possible during operation.
Component quality is always vital for the longevity of a PSU and Zalman are now using high quality Japanese capacitors. These offer greater stability at higher operating temperatures, frequencies and currents giving a high powered PSU like the ZM12050-Platinum the edge in reliability and performance.
It also incorporates heavy-duty protection circuitry which guards against over-current, over-power, over-voltage, over-temperature, under-voltage and short circuits.
As with most modern PSU designs, this unit features a modular cable system. This allows you to remove those cables which aren't needed, improving the appearance, maintainability and airflow inside your PC case. A further benefit is that all the cables themselves are flat which makes them less bulky and cable management even easier.
Eight PCI-E cables allow this PSU to support 4-way SLI and CrossFireX configurations making this the perfect PSU for high-end gaming enthusiasts.
- 80 PLUS Platinum certified PSU 89-93%
- Smart Fan control system - Fanless up to 40% load
- Guaranteed to provide 1250W continuous power
- High quality 105°C Japanese capacitors
- Multi-GPU ready for 4-Way CrossFireX and SLI
- Full Bridge and LLC resonance circuit with DC-DC module
- Smart fan control system
- Meets ErP 2010 Lot6 standby power standards
- Safety / EMI Approvals, CE, FCC, UL, CB, KC certified
- 5 Year warranty
Was £164.99 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Arozzi Torretta XL Gaming Chair - Red @ £149.99 inc VAT
The Arozzi Torretta XL is one cool gaming chair, which has a racing inspired look. High quality, thick padding on the arm rests, seat and, back gives you the highest comfort.
The Torretta XL chair is one of the first chairs to be designed for people with the need of a larger and wider chair. With the same features and design as its precursor, but with wider seat and backrest this chair will bring supreme comfort without feeling tight.
Features
- Colour: Red & Black
- Metal frame construction.
- Thick padded seat and backrest.
- Ergonomic design.
- Fabric upholstery material.
- 360 Degree swivel rotation.
- Adjustable armrest (height and rotation)
- Adjustable height gas-spring, supports up to 180KG.
- Tiltable seat with lock function
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
- 7 different colour choices.
Technical Details
- Shoulder Width: 590mm
- Waist Width: 450mm
- Seat Width: 480mm
- Chair Height: 1280mm
- Seat Length: 460mm
- Seat Height: 400-330mm
- Armrest Heights: 370-270mm
Was £199.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Arozzi Torretta XL Gaming Chair - Blue @ £149.99 inc VAT
Features
- Colour: Blue & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Arozzi Torretta XL Gaming Chair - Orange @ £149.99 inc VAT
Features
- Colour: Orange & Black
- Ergonomic design.
Technical Details
- Seat Width: 480mm
ORDER NOW
Thermaltake Urban S71 Windowed Midi Tower Case - Black @ £89.99 inc VAT
Urban S71 windowed mainstream full-tower, categorized in Thermaltake latest chassis collection – Urban Series. The entire series has a simple and elegant aesthetic, design for users who looks for everything but a flamboyantly appearance.
Features:-
- Exquisite Design
Built with brushed aluminum finish front door panel to mask the extrusive drive devices, not only unify the appearance, but also provide a simple yet sophisticate aesthetic.
- Handy I/O ports
The front-top panel has implemented two of latest data transfer SuperSpeed USB 3.0 ports along with two USB 2.0 ports, a HD microphone and headset jacks, to grand direct access when needed.
- Easy Hot Swap
Top-mounted 2.5” or 3.5”HDD Docking Station enables blazing fast file transfer and effortless hot-swap drive replacement design for easy setup or removal of HDD.
- Innovative tool-less design
The latest tool-less innovation with 5.25” & 3.5” tool-free drive bay design minimized the hassles of installing ODD and HDD devices.
Specification:-
- Case Type: Full Tower
- Side Panel: Transparent Window
- Colour: Exterior & Interior : Black
- Material: SECC
- Expansion Slots: 8
- Motherboards 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX), 12” x 13” (Extend ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
- PSU Standard PS2 PSU (Optional)
- LCS Upgradable: Supports 1/2” ,3/8”,1/4", water tube
- Fans:-
- Top: 1 x 120mm or 2 x 120mm
- Rear: 1 x 120mm
- Cooling System:-
- Front (intake) : 200 x 200 x 30 mm fan (600~800rpm,13~15dBA)
- Rear (exhaust) : 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust) : 200 x 200 x 30 mm fan (600~800rpm, 13~15dBA)
- Bottom (intake) : (Optional) 120 x 120 x 25 mm fan or 140 x 140 x 25 mm fan
- Drive Bays:-
- Accessible : 3 x 5.25’’, 1 x 3.5’’
- Hidden : 5 x 3.5’’ or 2.5’’
- Docking : 1 x 3.5” or 1 x 2.5”
- Dimension: 534(H) x 213(W) x 584(D) mm
- Net Weight: 10.5Kg / 23.2 lb
*CPU cooler height limitation: 160mm VGA length limitation: 344mm
Was £99.95 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1600W Fully Modular "80 Plus Platinum" Power Supply - Black @ £199.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have added the Leadex 1600W Platinum to their range, offering up to 92% efficiency with class leading features, as well as offering a huge 1600W capacity, one of the highest wattage Platinum rated PSU's on the market.
All Leadex Platinum Power Supplies feature a fully modular design, 140mm silent DBB Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 220 mm (W x H x D)
- Fan: 140 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Form Factor: ATX12V 2.2 / EPS12V 2.92
- Power: 1600W
- 3.3V: 24 A
- + 5V: 24 A
- + 3.3V & + 5V combined: 120 W
- + 12V: 1,599.6 W / 133.3 A
- -12V: 6 W / 0.5 A
- + 5VSB: 15 W / 3.0 A
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-1600F14HP
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 9 x 6+2-Pin-PCIe
- 5 x 6-pin PCIe
- 18 x SATA
- 5 x 4-Pin-Molex
- 2 x Floppy
- Warranty: 5yr
Was £254.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
This one is a special supported deal by SuperFlower, there's no way I'll be able to get near this price again, almost the same cost as the 1200W!!!!
Corsair Graphite 380T Portable Mini ITX Case - White (CC-9011060-WW) @ £94.99 inc VAT
The Graphite Series 380T packs a powerful punch in a portable Mini-ITX PC case. A built-in carrying handle makes transport a breeze. It’s easy to build the road-ready computer of your dreams within a spacious, easy to access interior with room for an extra-long graphics card. You can keep things cool with mounts for up to six fans and a convenient front panel three-speed fan controller.
The Graphite Series 380T Mini-ITX PC case doesn’t make any comprises inside or out. The sleek design derives from Corsair’s most-celebrated computer cases -- featuring eye-catching rounded corners as well as multiple color options. A built-in carrying handle lets you take it anywhere with ease.
Fine-tune air-cooling performance with the three-speed fan controller. Visible through the windowed side panels, the roomy and easy to access interior delivers major real estate for your next rig with space for a full-length graphics card, six fans, and four drives. Plug in your USB 3.0 devices and headset through the front panel. Now you’re ready to hit the road in style.
Features:
- Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
- Built-in carrying handle makes it a portable powerhouse
- Included 140mm LED intake fan and 120mm exhaust fan
- Control freak? Customize cooling and noise level with the convenient three-speed fan controller
- Swap drives easily -- without tools -- in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
- Built-in internal lighting with to show off your system
- Easy connectivity with front panel USB 3.0, headphone, and microphone ports
- Maximum CPU Cooler Height -150mm
- Maximum GPU Length - 290mm
- Maximum PSU Length - 160mm
- Mounts for 5 Fans
- Front fan mounts: 1 x 200/140mm, 2 x 120mm
- Side fan mounts: 2 x 120mm
- Rear fan mounts: 1 x 120mm
Radiator compatibility:
- Front - 140mm or 120mm
- Bottom - 240mm
- Rear - 120mm
Was £117.95 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Corsair Graphite 380T Portable Mini ITX Case - Yellow (CC-9011065-WW) @ £94.99 inc VAT
Features:
- Mounts for 5 Fans
- Bottom - 240mm
- Rear - 120mm
ORDER NOW
AK Racing Pyro Gaming Chair Black & Red @ £159.95 inc VAT
AK Racing seats offer stylish esports looks alongside well considered ergonomics.
Boring office chairs are the last thing any gaming enthusiast wants! Don't suffer these boring solutions any longer, now you can have the same style chair that professional gamers use in tournaments around the world!
Perfect for office workers and gamers, AK Racing seats are a high quality and exciting solution to the various health disorders resulting from bad posture.
Styled after Race Car seats and implementing very high quality materials, AK Racing are the ultimate desk accessory and compliment your pro gamer attitude perfectly whilst being hard wearing and durable.
Featuring supportive seat bolsters, just like a real bucket seat, your posture will be perfect whilst at your desk.
All AK Racing seats come with multiple points of adjustability so that you can tailor the position of the seat perfectly.
Features
- Quality upholstery material. PYRO series uses PU Leather.
- Metal Construction: Each seat has a sturdy metal frame.
- High quality, comfortable hard foam, not prone to deformation over time.
- Adjustable Armrests.
- Adjustable Back Angle: 180-degree backrest adjustment allows you to adjust it to your needs.
- Adjustable tilt, height and back.
- Reinforced wheels: designed not to scratch hardwood or laminate floors.
- Very Strong Metal base with class 4 gas lift support up to 180KG.
- Cushions Included for optional lower back and head/neck support.
Dimensions
- Shoulder Width: 565mm
- Waist Width: 550mm
- Seat Width: 365mm
- Back Height: 950mm
- Seat Length: 560mm
- Seat Height: 510-430mm
- Armrest Heights: 340-270mm
Only £159.95 inc VAT.
ORDER NOW
BitFenix Pandora Micro-ATX Case w/ Icon Programmable Display - Silver @ £69.95 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. On the front of the case is another innovation dubbed BitFenix ICON™ - a programmable display that can be customized with a simple drag and drop interface, making it simple to personalize the look of your case whenever inspiration strikes. Despite its slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 350mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
- Material: Aluminum, Steel, Plastic
- Dimensions: 160 x 420 x 465
- Form Factor: Micro ATX, Mini-ITX
- LCD: 2.4" TFT, 240 x 320
- 3.5" Driver Bays: 2
- 2.5" Driver Bays: 3
- Cooling top: 120mm x 1 (included)
- Cooling Front: 120mm x 2 (1 included)
- PCI Expansion slots: 5
- Front Panel: USB 3.0 x 2, HD Audio
- Power Supply Support: ATX, up to 180mm in length
- USB 3.0 x 2, HD Audio
Was £89.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
BitFenix Pandora Core Micro-ATX Case - Silver Windowed @ £59.99 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. Despite it's slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 350mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
Was £83.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Aerocool Xpredator Cube Micro-ATX Case - Black / Orange @ £51.95 inc VAT
Finally, the cube styled case of the popular Aerocool gaming case model "XPredator" has hit the market. Not only it possesses the original XPredators look, it is also more compact and easier for transportation. This case was designed for everyone including heavy gamers who will find this case incredible for its excellent airflow performance and watercooling abilities.
• Super cube gaming case solidly built with 0.7mm Steel
• Unique side bar design to take the strength of chassis to the next level
• PSU bracket makes installation of PSU easier
• Largely increased airflow by mesh design of front and top panels
• Completely removable ODD rack for ease of installing water cooling system
• Most parts can be removed by screw drivers for personal molding needs
• Supports DUAL 240/280mm water cooling radiators
• Pre-drilled holes for water cooling tubes
• HDD rack is double-secured by 2 screws to ensure the precious data don’t get damaged during transportation
• Shock-proof rubber pads for 3.5" HDDs and PSU
• 2x USB3.0/ HD Audio & MIC
• Separate fan positions for exhausting the heat from HDD and motherboard
• Large Acrylic window for clear viewing
Specifications:-
- Dimensions: 280 x 380 x 350 mm (W x H x D)
- Weight: 7.2 kg
- Material: steel (0.7 mm), plastic
- Color: Black/ Orange
- Form Factor: Mini-ITX, Micro-ATX
- Total fan possible:
- 1x 200 mm / 2x 140/120 mm (front)
- 2x 140/120 mm (rear)
- 2x 140/120 mm (cover)
- Thereof pre-installed:
- 1x 200 mm (front; LED)
- 1x 140 mm (rear)
- Radiator Mountings (partial waiver of fan slots):
- 1x max. 280/240 mm (front)
- 2x max. 140/120 mm (rear)
- 1x max. 280/240 mm (lid, with waiver of 5.25-inch frame)
- Fan control: 2 channels, max. each 15 W, infinitely
- Filters: front, power supply (removable)
- Drive Bays:
- 1x 5.25 inches (external)
- 3x 3.5 inch (internal; tools)
- 5x 2.5 inch (internal; 3x instead of 3.5 inches, 2x on 5.25-inch frame)
- Power supply: 1x Standard ATX (optional)
- Expansion Slots: 4
- I / O Panel:
- 2x USB 3.0 (internal connection)
- 1x per Audio In / Out
- Maximum PSU length: 320 mm
- Maximum video card length: 320 mm (with front fan)
- Maximum video card length: 345 mm (without front fan)
- Maximum CPU cooler height: 165 mm (with lid fans)
Maximum CPU cooler height: 190 mm ??(without lid fan)
Was £59.99 Inc. VAT
Only £51.95 inc VAT.
ORDER NOW
Aerocool Xpredator Cube Micro-ATX Case Red/Gold @ £54.95 inc VAT
Specifications:-
- Weight: 7.2 kg
- Color: Gold,Red
- 1x 140 mm (rear)
- 1x max. 280/240 mm (cover; do not set 5.25-inch frame)
- Fan control: 2 channels, max. each 15 W, continuously
- Drive Bays:
- 1x 5.25 inch (external)
- I / O Panel:
- 2x USB 3.0 (internal connector)
- Maximum CPU cooler height: 190 mm (without lid fan)
Was £63.95 Inc. VAT
Only £54.95 inc VAT.
ORDER NOW
AeroCool Sixth Element Full Tower Case - Black/Blue @ £34.99 inc VAT
The Sixth Element is solidly constructed from 0.6mm SECC Japanese steel and beautifully finished in an elegant black and blue colour.
The 6th element is extremely user-friendly and it gives the user great expandability and versatility. The screw-less feature and pre-cut holes on the motherboard plate (for tidy cable routing) make this chassis easy to work with. The pre-cut cable routing holes are also protected by high quality rubber to prevent cable damage from sharp edges. Finally a CPU hole has also pre-cut on the motherboard plate for ease or cooler assembly and removable.
This chassis offers great expansion capabilities. It can support four 5.25" devices, one 3.5" device (external) with included converter bracket. Internally the case can accommodate six 3.5" HDDs. Due to the depth of the case it is deep enough to support long high end graphics cards up to 400mm in length (when the middle HDD cage is removed). With the middle HDD cage installed, the chassis can support graphics cards up to 280mm in length.
The Sixth Element features many key locations for airflow. At the front and roof of the case, two 140mm LED fans are used (both supplied). There are also locations for one 120mm fan at the rear of the case and two 120mm fans on the side panel (not supplied). Finally the PSU cut-out features a filter to help prevent dust entering the system.
- Material: SECC 0.6mm
- Compatible Motherboards: ATX and Micro ATX
- Chassis Dimensions: 510(H) x 197(W) x 530(D)
- Drive Bays: 4 x 5.25" (External) with one 3.5" converter / 6 x 3.5" HDDs (internal)
- Expansion Slots: 7 Slots
- Max length space available for PCI cards: 280 or 400mm with middle HDD cage removed
- I/O Ports: 2 x USB 2.0 / e-SATA / Mic & headphone (AC97 & HD audio)
- Cooling options: Front - 1 x 140mm LED fan (included), Roof - 1 x 140mm LED fan (included), Back - 1 x 120mm fan (optional), Side panel - 2 x 120mm fan (optional)
Was £49.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Anidees AI-6B Midi Tower Case - Black @ £69.95 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior, with a brushed aluminum centre. In between lie a set of stealthy and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
Dimensions: 207 x 509 x 527 mm (W x H x D)
Material: steel, aluminum
Weight: 11 kg
Color: Black
Form Factor: ATX, Micro ATX, Mini-ITX
Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
Top Cooling: 2x 140 / 120 mm (lid, optional)
Filters: Front & Back
Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
Power Supply: Standard ATX 1x (optional)
Expansion Slots: 8 (without tools)
I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
Maximum graphics card length: 428 mm
Features: Elements made of brushed aluminum
- Cable Management
HDD and power supply decoupling
- Removable hard disk cages
Was £89.99 Inc. VAT
ORDER NOW
Antec P380 Performance Series Windowed Tower Case - Black/Gun Metal @ £122.99 inc VAT
Full Spec Here!
Was £152.99 Inc. VAT
Only £122.99 inc VAT.
ORDER NOW
BitFenix Prodigy 'Cheetah' Mini-ITX Cube Case - Black/Orange @ £42.95 inc VAT
We have made some amazing improvements to the Prodigy cases - Black/Orange. These new options offer great new stylish designs.
Specifications
- PCI Slots: x 2
Was £64.99 Inc. VAT
Only £42.95 inc VAT.
ORDER NOW
BitFenix Prodigy 'Embers' Mini-ITX Cube Case - Red/Black @ £42.95 inc VAT
We have made some amazing improvements to the Prodigy cases - Red & Black. These new options offer great new stylish designs.
Specifications
- PCI Slots: x 2
Was £64.99 Inc. VAT
ORDER NOW
BitFenix Prodigy 'Storm' Mini-ITX Cube Case - Black/Blue @ £42.95 inc VAT
We have made some amazing improvements to the Prodigy cases - Black & Blue. These new options offer great new stylish designs.
Specifications
- PCI Slots: x 2
Was £64.99 Inc. VAT
ORDER NOW
BitFenix Prodigy 'Gamma' Mini-ITX Cube Case - Orange/Blue @ £42.95 inc VAT
We have made some amazing improvements to the Prodigy cases - Orange & Blue. These new options offer great new stylish designs.
Specifications
- PCI Slots: x 2
Was £69.95 Inc. VAT
ORDER NOW
Cubitek Mini Center Mini-ITX Case - Black @ £27.95 inc VAT
This small form factor case from cubitek offers a stylish and sleel solution for the mini ITX form factor without breaking the bank.
Specifications:-
- Dimensions: 200 x 250 x 200 mm (W x H x D)
- Material: Brushed aluminum
- Weight: 1.5kg
- Color: Black
- Fan: no
- Drive Options:
- 2x 2.5 inch or 1x 3.5 inch (internal, bottom)
- Power Supply: Standard ATX 1x (optional), max. 150 mm length
- Expansion Slots: 2
- I / O Panel:
- 1x each Audio In / Out
- Maximum graphics card length: 180 mm
- Maximum CPU cooler height: 85 mm
Was £37.99 Inc. VAT
Only £27.95 inc VAT.
ORDER NOW
Lian Li PC-Q33WB Mini-ITX Cube - Black Window @ £64.99 inc VAT
The ideal of creating the PC-Q33 is to save user's space, the PC-Q33 can fit Mini-ITX mothorboards and ATX power supplies. PC-Q33 is designed to maximize the natural flow of air through vent holes located on the side and rear panels to cool components
Specifications:-
- Dimensions: 229 x 328 x 240 mm (W x H x D)
- Material: aluminum
- Weight: 2.18 kg
- Form Factor: Mini-ITX, Mini-DTX
- Fan (pre-installed):
- 1x 120 mm (rear)
- Drives:
- 2x 3.5 inch (internal, or 3.5-inch + 2x 2.5 inch)
- 3x 2.5 inch (internal, or 3.5-inch + 2.5 inch)
- I / O Panel:
- 2x USB 3.0
- 2x Audio
- Maximum PSU length: 200 mm
- Maximum CPU cooler height: 180 mm
- Maximum video card length: about 220 mm
Was £85.99 Inc. VAT
ORDER NOW
Xigmatek Talon Windowed Gaming Case - Black @ £50.99 inc VAT
Xigmatek’s innovative Talon Series mid-tower chassis is in a league of its own. The styling is reserved yet hints at the aggressive power hidden just below the surface. Deliberate and forward-looking design and functional elements guarantees a long life cycle; and the uniquely styled exterior
guarantees the Talon will be the centerpiece of your PC system for many years to come.
- Stealth series, silent mid-tower chassis supports ATX, micro-ATX, mini-ITX motherboards
- Top white LED backlit Xigmatek “X” Logo (On/Off Switchable)
- Large frontal air intake and top mounted hot air exhaust ports
- Elevated rear gives aggressive 25° front tilt, dramatically improving passive system airflow
from underneath the chassis
- Smoke black transparent top can be removed to install 2 x 140mm or 1 x 240mm radiator
- Top mounted I/O with 2 x USB 3.0, 2 x USB 2.0, HDA/AC’97 Audio In/Out jacks, Power/Reset
behind hidden access door
- 3 x 5.25” external drive bays
- Innovative 5+3 3.5” tool-free drive bays; 5 x 3.5” bays can be converted for 2.5” HDD use
- 8 x tool-free PCI slots; can accommodate up to 330mm full-length graphics cards
- Supports up to 180mm tall side-blow tower coolers
- Pre-installed silent 1 x 200mm front, 1 x 140mm rear Xigmatek Orange bladed fans with white
LED
- Tool-less chassis side panels and front panel removal and installation
- Smoke black transparent side window
- Bottom mounted PSU
Was £64.99 Inc. VAT
Only £50.99 inc VAT.
ORDER NOW
Lian Li PC-343B Cube HPTX Housing - Black @ £239.99 inc VAT
The Lian-Li PC-343B Modular Aluminum Cube Case; this is without a doubt the most complicated case Lian-Li has ever built. It allows you to setup different optional configurations on almost every inch of the case. One can install up to 18 different single 5.25" bay devices, or 30 Hard Disk Drives*, or a dual 120mm Radiator*, or a triple 120mm Radiator, up to two power supplies, up to 11 120mm fans*, and more!
The Lian-Li PC-343 modular design means that it is perfectly suited for any project that needs lots of space. Of course since it is built by Lian-Li, you can expect that perfect aluminum finish that lends elegance to any system.
Features:-
- Removable top panel with optional plates for radiator mounting
- Built-in multi-media I/O ports
- Optional Fan Filters
- 5.25" to 3.5" Floppy Bay Converter (optional)
- Removable Rear Mount Hard Disk Drive Cage (optional)
- 5.25" to 3.5" Hard Disk Drive Cage Converter (optional)
- Anti-Vibration rubber mounts for Hard Disk Drives
- Optional dual power supply plate
- Optional Liquid Cooling Radiator mounts
Specification:-
- Manufacturer Number: PC-343
- Dimensions: 460 x 520 x 565 mm (W x H x D)
- Color: Black
- Weight: 9.3 kg
- Form Factor: HPTX, ATX, Micro-ATX
Fan (optional):
- 4x 140 mm (cover)
- 3x 120 mm (rear)
- 2x 140 mm (bottom)
- 2x 140 mm (sidewall)
Drive Bays:
- 18x 5.25 inch (external)
- 4 x 2.5 inch (internal)
- Power supply (optional): Standard ATX 1x (tool-less, filter)
- Expansion slots: 11 (Tool-less)
I / O Panel:
- 4x USB 3.0
- 2x Audio
- 1x eSATA
- Maximum video card length: 400 mm
- Maximum CPU cooler height: 230 mm
Was £284.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
NZXT H2 Classic Silent Midi Tower Case - White @ £59.99 inc VAT
NOISE – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
- Touch powered fans with fan filter for easy maintenance and fan swapping
- 30W 3-step fan control for airflow settings at 40%, 70%, and 100% of maximum fan speed
- Top hot swap capable SATA HDD Dock (requires an AHCI capable motherboard and hot swappable HDD) and USB 3.0 port for the most up to date function
- 8 Front facing HDDs for optimal airflow
- Noise dampening foam and a top magnetic fan cover for minimal PC noise
- Ample 25mm space behind motherboard for cable management
- Dimensions: 215 x 466 X 520 mm
- VGA Clearance Maximum: 310 w/o HDD, 250mm with HDD
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm ( included )
- Top Cooling: 1 X 140mm
- Drive Bays: 3 x external 5.25" & 8 x Internal 3.5"/2.5" Slots
- Screwless Rail Design
- Expansions Slots: 7
- Motherboard Support: ATX, MICRO-ATX, BABY AT
Was £79.99 Inc. VAT
ORDER NOW
Xigmatek Gigas Micro ATX Cube Case - Silver @ £64.99 inc VAT
Balance meets awesome design, functionality and size. Small outer dimensions but huge capability of housing high end hardware is one of the main advantage of our new HYBRID Chassis “GIGAS”. Supporting 2*5.25” ODD, 6*3.5” HDD and 2*2.5” SSD, and total length of 320mm or 12.5” graphic cards. Optimized airflow system by four preinstalled 1000 RPM fans and standard 120mm heat-pipe side blow CPU cooler. Start the GAME with GIGAS!!!
- Full aluminum Micro-ATX chassis for gaming and HTPC.
- Available for 12cm side-blow heatpipe cooler within 160mm height.
- Dual 330mm high-end long graphic cards available.
- Six 3.5" HDD space with anti-vibration rubbers.
- Two 2.5" SSD/HDD available.
- Two external 5.25" bays for optical drive and HTPC control panel.
- Two preinstalled 12cm 800RPM front black fans and two 12cm rear fan space for optional.
- One USB3.0 front port available.
- Dimensions: 278(W) x 322(D) x 396(H) mm
- Drive Bays: 5.25” External x 2
- Drive Bays: 3.5” Internal HDD x 6 on two HDD cages (with anti-vibration rubbers)
- Drive Bays: 2.5” Internal HDD x 2 on two HDD cages
- Expansion Slot: 4 slots (Available graphic card length: 320mm)
- Motherboard Support: Micro ATX, ITX
- Front Cooling: Pre-installed 120mm black fans x 2 (1000RPM)
- Rear Cooling Fan: Pre-installed 120mm black fans x 2 (1000RPM)
- Max CPU cooler height: 160mm
- Water-cooling: 120mm All-In-One water-cooling device available
- I/O Panel: Power button, Reset button, USB3.0 x 1(internal 20pin), USB2.0 x 2, HD Audio in/out x 1
Was £86.99 Inc. VAT
ORDER NOW
Streacom ST-NC1S-GK Intel NUC Aluminium Housing - Silver @ £49.99 inc VAT
Designed for the Next Unit of Computing (NUC) platform, the Streacom NC1 delivers silent computing in an impossibly small package. The case is modular, meaning that front, rear and CPU cooler can be replaced to accommodate future NUC motherboards and its acrylic sides allow for internal WiFi and Bluetooth signals to propagate, keeping the outside sleek and clutter free.
The optional VESA compatible mount allows it to be hidden behind the monitor, but with looks like this, we think most people will have it on display.
Features:-
- Compact - Small footprint, ideal for use in places with limited space The optional VESA mount turns any display into a compact PC
- 0DB Computing - Totally Silent Solution - With its built in passive (fanless) CPU and chipset cooler, it is possible to set up a totally silent computer, 100% noise free.
- Timeless Design - Minimalist design and the use of high-quality materials charactize this case
- Connectivity - Acryilic sides for best WiFi and Bluetooth reception
Specification:-
- Chassis Material: Extruded & Milled Aluminium, Acrylic sides
- Colour: Silver
- Motherboard Compatibility: Intel NUC Platform
- HDD Drive Support: Non, mSSD on Motherboard
- Expansion Slot: Non, PCIe on Motherboard
- USB Ports: Fixed to Motherboard
- Cooling: Finned Top Panel 20W
- Dimensions: 150 × 112 × 48mm (W×D×H)
- Power Supply Support: External AC Adapter (Supplied with Motherboard)
Was £69.95 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Xigmatek Midgard III Midi-Tower - Black @ £48.95 inc VAT
Includes pre-installed high performance silent (black with black fan blades) Xigmatek XOF fan with FCB (Fluid Circulative Bearing) for ultimate exhaust capabilities.
Hidden I/ O panel includes 2 x Super-Speed USB 3.0, 2 x High-Speed USB 2.0, HD Audio In/Out jacks, Power/Reset.
Capable of mounting ATX, Micro ATX, mini-ITX Motherboards. (with backside hole for CPU cooler)
Innovative 6 X 3.5” HDD can be converted to 2.5” SSD for easy mix and match.
- Newly designed intake from elevated panels insures maximum airflow and minimizes sound pollution.
- Standard P/S2 ATX/EPS power supply units on downside space with anti-vibration rubber.
- Can mount up to 330mm Gaming Graphic cards
- Black Grand Piano paint on panels creates luxury and prestige.
- Thick side panels makes the chassis strong and secure.
- CPU cooler support : 160mm
- Add-on card slot X 7
Specifications:-
- Dimensions: 260 x 515 x 409 mm (W x H x D)
- Material: Steel (Body, sides)
- Color: Black, partly high-gloss
- Form Factor: ATX, Micro-ATX, Mini-ITX
- 2x 120 mm (front)
- 1x 120 mm (rear)
- 2x 140/120 mm (lid)
- 1x 120 mm (bottom)
- Of this pre-installed:
- 1x 120 mm (rear)
- Radiator Mountings:
- 1x max. 240 mm (lid, max 50 mm height.)
- Filters: front, power supply (remove)
- Drive Bays:
- 3x 5.25 inches (external, tools)
- 6x 3.5 / 2.5 inch (internal, 2 HDD cages, 3.5 inches without tools)
- I / O Panel:
- 2x USB 2.0
- Qi Wireless Charging Dock (inductive power transfer)
Maximum graphics card length: 330 mm
- Maximum CPU cooler height: 160 mm
Was £64.99 Inc. VAT
Only £48.95 inc VAT.
ORDER NOW
Zalman Z12 Plus Midi Tower Windowed Case - Black @ £44.99 inc VAT
Up to 5 system fans available to cool down the system efficiently. Supports bottom PSU installation for effective cooling of PSU and inner space of case. Front USB ports, audio socket, power button, reset button & top USB. Dust filters on the bottom and front prevent dust from entering. 3in1 Adapter Tray is provided for installing FDD / 3.5' HDD / 2.5' HDD/SSD. Place smart phone, external hard drive on the stand next to the USB port for convenient charging and connection. Tool-Free HDD slide tray for convenient installation with anti vibration rubber. Anti-vibration Rubbers on the bottom of the case and the PSU installation area offer the vibrations free Quiet PC Environment.
- Dimensions: 215(W) x 470(H) x 480(D) mm / 8.4(W) x 18.5(H) x 18.8(D) inch
- Weight: 7 kg / 15.43 lb
- Materials: Plastic, Steel
- Motherboard Compatibility: Standard ATX / Micro ATX
- Power Supply Compatibility: Standard ATX / ATX12V
- PCI/AGP Card Compatibility: Full Size, 290 mm / 11.4 inch
- Drive Bays: 5.25' External Bay x 4 / 3.5': Internal Bay x 5 / 2.5': Internal Bay x 1
- Common (3in-1): Internal Bay 5.25'/3.5'/2.5' x 1
- Top Cooling: (Fans) 120mm Fan Vent x 2 (2 Fan optional)
- Rear Cooling: 120mm Fan Vent x 1 (1 Fan included)
- Font Cooling: 120mm Fan Vent x 1 (1 Blue LED Fan included)
- Bottom: 120mm Fan Vent x 1 (1 Fan optional)
- Expansion Card Slots: 7 Slots
- I/O Ports: Headphones x 1, Mic x 1, USB 2.0 x 2, USB 3.0 x 2
Was £54.98 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Zalman HD501 Home Theatre PC Case - Black - ** FREE BE QUIET! 120mm FAN ** @ £59.99 inc VAT
Available in two different styles, the HD500 series HTPC cases not only look great but they also offer excellent cooling for a HTPC chassis. The minimalist styling, brushed aluminium finish and the rounded corners give these cases a distinctive look. The optical drive, I/O ports and a hot-swappable HDD are all hidden behind front aluminium flaps to maintain the elegant finish.
The HD500 series can accommodate Micro ATX as well as Standard ATX motherboards. This makes it possible to install high performance components without having to worry if a large CPU cooler or graphics card will fit. The cases are compatible with coolers no taller than 130mm. Finally, with the HD500 series you can install long PSUs due to the extra space.
One of the down sides to HTPC case is the fact they can become quite warm due to the size of the chassis'. Zalman have helped to solve this problem by incorporating many ventilation holes. At the rear and the left side of the case you will find that there are two 80mm fans and 120mm fan. These fans are designed to extract the hot air generated inside the chassis. The intake fan is also 120mm which blows the cooler air from outside the chassis over the HDDs
Both the HD501 and the 503 have the facility for one hot-swappable 3.5" hard drive to be installed. This hard drive is installed into a 5.25" drive bay rather than a 3.5". As you would expect the HDD is mounted on anti-vibrational rubber screws. The hot-swappable HDD is accessed by lowering the bottom flap.
For convenience Zalman have also made available at the front of the case several common ports. Two USB, one e-SATA, one headphone and one microphone port are all available. These ports are hidden behind the same flap that hides the hot-swappable HDD.
Features
- 450(W) x 170(H) x 455(D)mm
- GPU Support: Up to 260 mm max length
- 5.25" Bays: 2 (Hot Swap Bay x 1)
- 3.5" Bays: 3 (SSD x 2)
- Front I/O Ports: 1 x Mic, 1 x Headphones, 2 x USB, 1 x e-SATA
- Sleek minimalist design
- Side ventilation for increased cooling
- Tool free anti-vibration HDD installation
- Hot-swappable HDD support
- Accommodates up to two SSDs
- Convenient front I/O ports
Specifications
- Enclosure Type: HTPC
- Dimensions: 450(W) x 170(H) x 455(D)mm
- Weight: 8kg
- Material: Aluminum / Plastic / Steel
- Cooling Components (Fans): Rear: 2 x 80mm fans, Side: 2 x 120mm fans(Optional)
- Supports Hot-Swap: SATA I, SATA II
- Available Colour: Black
Was £99.95 Inc. VAT
ORDER NOW
Enermax Platimax 1500w '80 Plus Platinum' Modular Power Supply (EPM1500EGT) @ £229.99 inc VAT
The Enermax Platimax 1500W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Dynamic Hybrid Transformer Topology
- Copper Bridge Array
- Multi Rail Design
- Special OC Edition
- Future ready and flexible
- Full Modular Cable Management
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- High Quality Japanese Capacitors
- 5 Year Warranty
Was £319.99 Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Enermax Platimax 1350w '80 Plus Platinum' Modular Power Supply (EPM1350EWT) @ £199.99 inc VAT
Fully utilize transformer’s quad magnetic quadrants energy to provide maximum switching efficiency and outstanding KW output stability.
World’s leading modular cable PSU series with 89-94% efficiency @ 20-100% load. Compliant with 80PLUS® PLATINUM efficiency requirement.
Specification:-
- Type: ATX12V / EPS12V
- Maximum Power: 1350W
- Fans: 1 PFC Active
- Main Connector: 24Pin+12V Rails
- 6PCI-Express Connector 8 x 6+2-Pin
- SATA Power Connector 14
- SLI Ready / CrossFireCrossFire Ready
- Modular: Full Modular
- Efficiency: 89-94% @ 20-100% loadEnergy
- Efficient80 PLUS PLATINUM Certified
- Over Voltage Protection: Yes
- Input Voltage: 110-240VAC (Max. range: 100-264VAC)
- Input Frequency Range50-60Hz (Max. range: 47-63Hz)
- Input Current: 14 - 6.5AOutput+3.3V@24A, +5V@24A, +12V1@20A, +12V2@20A, +12V3@30A, +12V4@30A, +12V5@30A, +12V6@30A, [email protected], +5VSB@3A
- Connectors1 x 24pin & 8pin MB/CPU
- 1 x 8pin & 4pin 12V CPU/RAM
- 4 x (2 x PCI-E 6+2pin)
- 3 x (4 x SATA)
- 2 x (4 x 4pin Molex + FDD)
- 1 x (2 x SATA + 2 x 4pin Molex)
- Warranty: 5yr
Was £229.99 Inc. VAT
ORDER NOW
Silverstone Strider Plus 850W Modular '80 Plus Silver' Power Supply (SST-ST85F-P) @ £89.99 inc VAT
The Strider series, as the oldest and most versatile power supply line from SilverStone, has models with myriad of innovative features and rating from 350W all the way up to 1500W. To build on this impressive lineup, SilverStone engineered a new generation of power supplies that combine more important features than ever before. The Strider Plus models, ST75F-P, ST85F-P, and ST1000-P are highly efficient (80 PLUS Silver level), compact enough to fit in nearly any system (160mm depth), have tightly regulated performance of ±3% from a single +12V rail design, and equipped with a quiet but cool 135mm fan. To top these features off, the power supplies also come with 100% modular cables with all the important connectors to support current and future graphics card specifications. For enthusiasts that are looking for a power supply with all the right features to make a high performing and aesthetically pleasing system, any one of the Strider Plus models will fulfill the task with maximum satisfaction.
- 80 PLUS Silver
- 850W 24hour continuous power output with 40?operating temperature
- 950W peak power
- 100% modular cables
- Efficiency 85%~88% at 20%~100% loading
- Class-leading single +12V rail with 67A (peak 72A)
- Strict ±3% voltage regulation and low ripple & noise
- Japanese main capacitors
- Silent running 135mm fan with 19dBA minimum
- Dual EPS 8pin connectors support
- Dual PCI-E 8pin and four PCI-E 6pin connectors support
- Support ATX 12V 2.3 & EPS 12V
- Active PFCcombined +12V: 804W/67A(Peak 72A)
- Input Voltage: 90V~264V
- Input Frequency Range: 47Hz~63Hz
- Active PFC(PF>0.95 at full load)
- Efficiency: 85%~88%(20% to 100% loading)
- MTBF: 100,000 hours at 25°C, full load
- Operating temperature: 0°C ~ 40°C
- Protection: Over current protection / Over power protection / Over voltage protection / Under voltage protection / Over temperature protection / Short circuit protection / No load protection
- Connectors: 1 x 24 / 20-Pin motherboard connector(550mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm) / 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm) / 2 x 8/6-Pin PCIE connector(550mm) / 2 x 6-Pin PCIE connector(550mm) / 6 x SATA connector(500mm / 250mm / 250mm) / 6 x 4-Pin Peripheral connector (500mm / 250mm / 250mm) / 2 x 4-Pin Floppy connector(500mm / 250mm / 250mm / 150mm)
- Colour: Black (Lead-Free Paint)
- Cooling System: Silent 135mm fan
- Noise Level: 19dBA-36dBA
- Dimensions: 150 mm (W) x 86 mm (H) x 160 mm (D)
- Weight: 2.9 kg
Was £108.95 Inc. VAT
ORDER NOW
Silverstone Strider Essential Gold - 500W (SST-ST50F-ESG) @ £49.99 inc VAT
SilverStone Essential Gold are PSUs with 80 PLUS Gold certification within the affordable Strider Essential series. They retain practical and reliable fixed-cable layout from other Strider Essential PSUs and adhere to the same outstanding characteristics from all Strider series PSUs with no comprise in quality and reliability.
The 80 PLUS Gold certification ensures that Strider Essential Gold PSUs produce 40% less wasted heat from energy conversion compared to PSUs with basic 80 PLUS certification for lower burden on cooling and electricity consumption. In addition, features from higher-level Strider series such as ±3% voltage regulation, high amperage single +12V rail design and multiple GPU support are also preserved to provide the best quality solutions at any price.
Features:-
- High efficiency with 80 PLUS Gold certification
- 24/7 continuous power output with 40? operating temperature
- Multiple protection circuitry
- PCI-E 8pin and PCI-E 6pin connectors support
- Built-in silent & durable hybrid ceramic bearing (HYB) fan
- Active PFC
Specification:-
- Amps +3.3v: 24A
- Amps +5v: 20A
- Amps +12v: 39A
- Amps +5VSB: 3A
- Amps -12v: 0.3A
- combined +3.3, +5V: 120W
- combined +12V: 468W
- Input Voltage: 90V~264Vrms
- Input Frequency Range: 47Hz ~ 63Hz
- PFC: Active PFC(PF>0.95 at Full Load)
- Efficiency: 87%~90% @ 20% ~ 100% loading
- Protection: Over current protection, Over power protection, Over voltage protection, Under voltage protection, Over temperature protection, Short circuit protection
- Connectors:-
- 1 x 24-Pin motherboard connector(500mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(600mm)
- 2x 8/6-Pin PCIE connector(500mm / 150mm)
- 1 x SATA connector(550mm)
- 4 x SATA connector(550mm / 50mm / 50mm / 50mm)
- 4 x SATA connector(550mm / 155mm / 155mm / 155mm)
- 3 x 4-Pin Peripheral connector (705mm / 155mm / 155mm)
- 1 x 4-Pin Floppy connector(705mm / 155mm / 155mm / 100mm)
- Cooling System: Single 120mm HYB fan
- Noise Level: 18 dBA minimum
- Dimension: 150 mm (W) × 86 mm (H) × 140 mm (D)
- Weight: 1.95kg
- Form factor: ATX
- Certification: 80 PLUS Gold
Was £60.95 Inc. VAT
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - White @ £89.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Leadex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features
- 80 PLUS ® Gold Certified, 90%, 92%, 89% Efficiency At 20% 50% 100% Rated Load
Specification
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Output: +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimensions: 200mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was £102.95 Inc. VAT
ORDER NOW
I'm good to you lot :)
We've actually sold a lot more of those than we ever expected, however as there is no more stock available to buy, we're doing a crazy deal for the ones we have left.
