Cinebench 9.5
13 Dec 2003
UK
Cinebench Benchmark
saw this plastered over at other forums, lets see what the fuss is about with this cpu rendering benchmark :D
get it here
use the CPU Benchmark Rendering (X CPU)
AMD AM2 4600 (Dual Core) @ 2.8Ghz - 28 seconds to render the scene
Stelly said:
not bad at all... what is your 6600 running at?
Stelly
At stock, was running at 2.9 ghz, had BSOD of Bad pool caller yesturday so I put back to stock.
Rob
sorry so whats the fuss about ...... Cinebench 9.5 is fully multi - core aware so a four core cpu halves the time taken to render what a dually does (give or take a few %)
Surely thats what everyone would expect.............
Hi,
Using DFI Infinity with 2gb Geil RAM 800mhz.
CPU cooling by the Arctic freezer pro, idle around 42c, full load 60c. one thing that does worry me is my NB is running at 70c :eek: .
Looking at water cooling or the scythe.
Rob
RJC said:
Hi,
Rob
i remember that board, you need active cooling on the northbridge.
I did manage 3.6Ghz from my 6600 though on air and im sure it was with a low end coolermaster aquagate..
I thought active cooling might be the case, had a look at the Thermalright HR-05 tower, one thing that concerns me is the arctic cooler covers part of the std passive heatsink (1 or 2 mm) so I will need to have measure up.
Thats were the watercooling might come in handy (swiftech) and by a northbridge adaptor.
Rob
Merom @ 3.25ghz. Will re-run with Conroe later.
If you run the single test as well as the multi, it'll give you a speedup figure :)
spec in sig - 1m06s :(
....nah, i'm not sad really. this pc is still more than fast enough for what i need. of course i need a new gfx card (my x800pro@xt pe died the other day). but i never encode/render/crunch anything, so dual/quad core would be wasted on me. :D
I think you might be surpised at how fluid windows is - especially if you have several background tasks on auto startup - with even a basic dual core cpu, let alone if you actually game regularly or just do a bit of multitasking.
I completely agree with you regarding quad though, thats really only necessary for encoding etc as you mentioned
