Cisco 1720, why isnt it copying running-config > startup-config :(
1 Dec 2004
S.Wales
Im doing a very basic config on a Cisco 1720 which im learning on, basically the router has been reset. Im logging in, changing the hostname from Router to Morandarouter1, enabling the secret password, then I use the
"copy running-config startup-config" command, this copies over the config to the startup config, I confirm this by then running "show startup-config" I can see the changes I have made, I then proceed to re-boot the router, when the router comes back up, it has reverted back to "Router" and no password.
Any ideas why it keeps doing this ?? Im following the official Cisco user guide on this one. :confused:
Check you have the confreg value set correctly:
do a 'sh ver' and it'll tell you what it is at the end
if it's 0x2142 that's your problem, skip into conf mode and do 'config-register 0x2102'
then write that to mem and you're sorted.
basically 0x2142 is a value to tell it to ignore the start config on boot. 0x2102 will boot normally. There are other options but 2102 is the right one in 99% of situations...
Ah, that will be my problem then, I remember setting the config to 0x2142 when I was following the password reset procedure guide.
I will give this a go. Thanks :)
