clean install backup help please :)
11 Dec 2011
Hull-Oxford
Im having issues with the PC where it keeps freezing and the sound buzzes for a second or two at random.
So i'm doing a clean install, which i need to do anyway as i never partitioned my drive properly the 1st time.
My question is; I have a backup file created by Windows Backup saved on a separate HDD of my files only (not a full system image), so, if i do the re-install (format the primary hdd) do i use a restore function in the clean windows install? and does this put all my files back as they were without any file path problems?
also, by doing this, is there a possibility that the problem i have now will re-occur due to the error being within the data files?
Thanks in advance :D:D
The initial problem you describe could have a number of different causes but once you have done a clean install make sure you grab all the latest drivers from the manufacturers website. When you restore the files you backed up they will be placed exactly as they were when you run the backup wizard to start with.
Thanks a lot :)
could you also give me some pointers as to what the causes could be? (I do have a thread on this in general hardware btw.)
Could be related to a driver crashing, could be your HDD or even RAM. If it still happens after doing a clean install with the latest drivers then test your HDD using the manufacturers test tool and if that's all clear then run Memtest to check the RAM. If you have an overclock then try removing it and testing again.
Yes, Windows backup is very good when it comes to restoring data, it''ll even do it from a network location.
