Cleaning CPU's
I was about to use nail varnish remover until I saw moisturiser on the label.
Don't think it makes much difference but I normally use the akasa stuff.
For now just use kitchen roll or toilet paper and am not gentle at all really.
Just wipe it off clean and reapply.
Hear, hear. Kitchen rolls work for me too
Take it out and put it in the Vise. Then give it a good old rub with this
Am I the only one to dry rub with bog roll?
No your not. :)
That or Kitchen roll.
The only time i use any form of solvent cleaner is when a standard heatsink has been used previously.
The thermal material on Intel and AMD stock heatsinks goes hard and needs some persuasion to come off.
Generally i use RS foam cleaner.
Also
I clean AMD CPU's in the socket if possible to avoid bending the pins.
Intel CPU's i clean out of the socket, often giving the pads on the bottom side a cleanup as well.
