Cleaning kit
4 Oct 2021
Uk
Hi.
I finally managed to get hold of some watercooling kit..but it is used .
Just wondering on what's the best way to clean it all...
Connect it up (pump , res, rad) and run tap water first then a flush with deionised?
Or is there some other fancy way.
I hooked mine up to the outside tap and just run it for 10 mins then run it through with deionised water (halfords 5l bottles are dirt cheap).
Yeah, I'm sure I read that somewhere which is why I mentioned it..looks like that's what I'm doing
And does anyone use deionised water in their loops these days or is it all fancy liquids ?
This is for an alpha cool 1080 rad which I will mount to the base of my 20u rack.
I now have a 5900x so it really needs some cooling
How to clean depends on how dirty it is tbh. If you can see inside the blocks and it doesn't look too bad then a flush through with tap water followed by a quick flush of deionised/distilled water should suffice. If you can see inside the blocks then I'd dismantle them and clean with an old tooth brush and some soapy water followed by a rinse of distilled or deionised water. For rads I've always filled with warm water and about 10% distilled vinegar and left if to stand for about 5 minutes before flushing out.
As for coolant I just use deionised water from Asda (its a couple of quid for about 2 litres) and a few drops of Mayhems Hades+ and Inhibitor+
all i use and a silver coil ..
I used to use a small amount of vinegar with distilled water to run for a bit with a filter then rinse with just distilled.
I run boiled water and some Zerex stuff from 20 odd years ago (I think it's pretty much water wetter/anti-freeze).
Had loops that are still clean after 10 years with that. You don't need fancy products.
