Cleaning my Pipes ;)
  • Thread starter Thread starter Sam
  • Start date Start date
Sam
Sam
12 Jan 2003
Surrey
Hi :)
I recentley purchased a Miltek Catback for my Trophy. It was 6 months old and by the look of it the guy wasnt took keen with his metal polish ;)
Soooo tonight i had a quick go with some megs metal polish and very very quickly got bored. Has anyone got any tips / tricks as to how to get my pipes nice and shiny again
Tnx
Sam
Wash and degrease them first, to get rid of any surface contaminants. Then use a metal polish such as Autosol with newspaper (yes that's right, newspaper) and work in small circles, then leave to dry and wipe off with a terry towel or cotton cloth.
It takes time, but it's worth the shine ;)
Autoglym metal polish and some #00 Wire Wool. Then just buff the rest off with a cloth.
