Hi guys. I'm currently cleaning my Bosch oven. I've hand scrubbed all the shelves and side supports. Removed the glass light cover and scrubbed that, although there are still black bits that won't come off, but looks a lot cleaner than before. I've just unclipped and removed the oven door, unscrewed the glass side, cleaned it thoroughly and put it back together.
I'm about to spray Mr.Muscle oven inside the oven cavity but this is where I'm stuck. Apparently the grill element mustn't get any chemical on it. Problem is, how do I clean the roof that the element is attached to? I can't remove the element without removing the whole built in oven, and if I spray Mr.Muscle between the loops of the element, it will undoubtedly drip onto the element. What's the worst that will happen if it does get Mr.Muscle on it?
). I'd just go for it and spray it down. Sometimes life is easier just ignoring the instructions! Correct me if I'm wrong here, but I can't see how it would break anything? Just open windows etc. and run it full whack for 30 mins or so after cleaning. Did ours recently like this and haven't had a problem- came up really nicely.
It's probably similar to the amazon stuff I linked, but I'll get the Lakeland one.
