Cleaning radiator and CPU block
15 Nov 2009
South east
Hi all I have some second hand watercooling parts from the MM and they could use a clean before I pop it in my rig what's the best way of doing that?
I have some Ispropanol 99% alcohol would that be safe or might it react with any seals?
As long as you take the o-rings out and allow it to dry properly IPA is exactly what I used and it worked great. (Ipa dries within minutes so hardly an issue)
I'm not even sure it would affect the o-rings but better safe than an expensive sorry.
Maybe I was rubbing too hard but IPA seemed to scuff up the acetal on my old EK block so I'd advise using it on the copper only.
Edit: missed the rads bit. I'm not sure about ipa on these I don't see why not but you'd need an awful lot of it. Just running hot water through it should be enough. I set mine up in the bath tub and just ran it until it turned clear.
the CPU block looks clean really but I might run hot water through it, the rad on the other hand has some gunk from the previous owner's loop and I have about 20gallons of ISO so figured it would do the job, can't see an issue with it on the rad myself but just in case
