- 5 Apr 2008
I have just bought:
Black Ice GTX 360 radiator (says water-based flux)
Watercool Heatkiller 3.0
Koolance 5870 block
Do i need to clean these? Does the 'water-based flux' mean i dont need to flush with vinager etc or will just a rinse with boiling water do? Do i need to take the toothbrush to the waterblocks?
What would you do?
Koolance 5870 block
What would you do?
At first it tends to be quite murky coming out, but after 2 or 3 times its pretty clear and good to go!
