Nem said:Start > Run > msconfig > boot.ini tab > check all boot paths button.
See what that removes for you.
Nick
Ol!ver said:I've got hidden files shown, always have. Problem is Boot.ini isn't there. It shows up in msconfig though which is odd.
Trigger said:Yeah, you need to set your machine to display system files. In My Computer, go to Tools > Folder Options > View > Show system files (Tick box) and hit apply. You will then see the file boot.ini at the root of C:\. Open it with notepad and take out the options you don't want![]()
|Ric| said:Right click on My Computer -> Properties -> Advanced Tab -> Start up and Recovery Settings -> Edit
That goes straight into you're boot.ini
lordedmond said:Trigger that will not show files with the S and H bit set only the H bis shown
Trigger said:Eh??? If you set windows to display system files, then windows will display system files. boot.ini is a system file and I think you can work the rest out for yourself![]()
um, It is where I said it was in my version and seems to have always been theresorry no
it should be control pannel / perfomance and maintenace / system / advanced / startup recovery there ye shall find
|Ric| said:um, It is where I said it was in my version and seems to have always been there
he said RIGHT CLICK ON my computer, not go into. Do tell me you know the difference between left and right click, please.lordedmond said:its contol pannel not as you stated my computer
