Guys, I was wondering if someone could tell me how to properly clean my blocks?
My GTX280 block is starting to get green bits on it, and the black screws that hold the acrylic plate onto the block have started getting rust on them.
I tried to clean it with a water/vinegar solution before, and it did look like it had cleaned it nicely, but when I checked the block the next day it had went all tarnished again.
I also found a website that recommended covering the block with tomato sauce and leaving it to sit for 30 minutes before scrubbing it off, this again made it look really bright and shiny, but the next day it was all dull and tarnished again!
Could it be something to do with rinsing it off with tap water that is causing this?
Should I use DI water for rinsing it off?
Any tips would be much appreciated guys, thanks in advance.
