- 12 Apr 2004
- Somewhere
Brilliant!dymetrie said:semtex
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Tomdun said:Push your tounge up against the roof of your mouth, then rock the little bone at the top of your nose, between your eyebrows. This worked a treat for me many times, can go from no breathing, to almost normal in a few seconds.
WantoN said:Rocking the clavicle is your best bet. As said:
Apply pressure to the point directly between and slightly below your eyebrows, you should feel a tiny shifting. Then press your tongue firmly against the roof of your mouth, just after releasing pressure to the point between your eyebrows. Alternate this and after about a minute, your nose should be clear
Ant![]()
Heh, either that or he's mr potatoe headsingist said:As for the quote above ........ rocking your collar bone probably won't clear your nose.
titchard said:Have a spicy curry or a chilli, it's my cure for a blocked nose.
Rich
andy8271 said:airwaves followed by xxx strong mints do the job.
if your hardcore replace mints with fishermansfriend :O
ps taking the mints or fishermanfriend after a pack of airwaves will most likely result in muchos strangeness
GlasgowTitan said:Post of the week. Also I havent seem fishermansfriends in years, where do I find them now?
Cybermyk said:Olbas Oil![]()
VaderDSL said:When I have a blocked nose I sniff PCP
