** CLEARANCE OFFER - CLEANING ACCESSORIES **
  • Thread starter Thread starter rjk
  • Start date Start date
Grabbed the 3X package and the wipes. Should come in handy for my phone (work for the NHS, the antibacterial properties are somewhat reassuring) and my screen thats not been cleaned properly since purchase...
Ridiculously overpriced at retail, somewhat more reasonable at this price.
I'd be lying if I said it didn't work. It's a great product, cleans very well (my screen was pretty darn grubby) with minimal effort and time - but you absolutely fly through the product...making it even less cost efficient than initially thought.
Just be aware the 'Antec Advance 3X Cleaner Spray 60mL - With Free Micro Fibre Cloth' is still using the wrong picture, you dont get the big bottle of spray :rolleyes:.
Not a bad price at £3.49 tho.
So these aren't for use on screens? What do i need to buy/make to remove the dry liquid blotches from the panel?
I have only used the following on Glass fronted screens.
The Antec Natural spray is a cleaner thats for use on screens. I have also used it on keyboard / mouse and it's very good at cleaning plastics. I expect this will remove marks from your panel.
The Antec Gel is a cleaner / sealer, I would have to say it's main use is screens. This coats the screen with a film of gel that protects the screen, it's a bit similar to how a wax/sealer for car body work protects the paint underneath it.
Both of the above have anti-static properties, and I've noticed the Antec Gel especially is keeping dust away longer from my screens.
Great, just bought both!
