just wanna throw my 2cents into the mist of forum chat i have had a clevo p170em same as overclockers laptops here mines eurocom but none the less there all the same as for the amd 7970m enduro problem it has long since been solved and is lovely these days and on top of that amd at last have direct drive downloads for our machines no more clevo old gpu driver then display adapter driver only....
Best method now days is go to clevo.com.tw get the chipset(motherboard driver)
intel graphics driver and ofc ur wireless card machine spec dependant
1. clean install windows 7 x64
2. chipset driver --- followed by reboot
3. intel cpu driver --- followed by reboot
4. amds latest beta driver (enduro not desktop)
** current release is 13.6 beta 1 its perfect as far as i can tell
Reboot then ur remaining drivers as normal
thats it ur golden you have the new ccc interface and graphics switching is seemless no more lacking fps or bsod or running intel igpu instead of your shiny new 7970m
links of official drivers below:
http://www.clevo.com.tw/en/e-services/download.asp
http://support.amd.com/us/kbarticles/Pages/amdcatalyst13-6WINBetaDriver.aspx
ps.p150em aka 15" varient models its exactly same process hope this helps any of you...
to reiterate (DO NOT INSTALL THE AMD CLEVO DRIVER FROM YOUR DVD OR THE WEBSITE THERE IS NO LONGER A NEED AND IT WILL ONLY SERVER TO CLUTTER UR REGISTERY)
I hope this helps some of you that are still struggling under the old launch problems of last year, any other problems or issues please feel free to get in touch ive had a 680gtx and 7970 in this machine and tbh the amd card is better now the drivers have matured so feel free to pm or what ever if anything boggling you!
