Climbing shoes
6 May 2009
I have been climbing for almost a year now, all indoor with a couple of outdoor sessions.
The first shoes I had were a bit too loose but the ones I have now are a tight fit - toes at the end and quite narrow on my wide feet. I can climb much better in them, up to about a v5 grade at the moment
It appears I have developed a 'bunion' - something I have heard of but only thought old people get them. Its a sticky out bone next to my big toe on my left foot. It used to only hurt a bit when climbing but I have noticed it without climbing shoes on for the past few days.
Is there anything I can do to stop it getting worse? I love climbing and want to carry on but not wreck my feet doing so
https://www.thebmc.co.uk/climbing-shoes-is-pain-insane
Sorry, as a climber you just have to accept deformed, ugly feet and mangled hands.:p
Are you sure your shoes are a good fit? Can you climb in them comfortably for a long time? It's worth trying different shoes until you find the best brand for you. I only wear La Sportiva now as they suit my feet.
Otherwise, I'd suggest investing in some foot care products from Boots etc. Anti-blister stick for points that rub, foot cream to moisturise the dry/hard skin and gel toe plasters.
Toes are fine, its just the sticky out bones on the sides of my feet lower than big toes.
Dammit, maybe my pinks are just too narrow for my wide feet
