Hi all,
Got a bit of an issue with my new build, the M.2 SSD from my laptop is too long for my new motherboard as it only accepts up to 80mm and mine is 110mm. I forgot to check! So now I'm looking to see how I can copy drives between each other. Our old systems are as follows:
Wifes Q6600 tower with a 250gb Samsung SSD
My i7 laptop with 250gb M.2 SSD and 1TB 2.5" HDD
The idea was for the Q6600 rig to be retired so therefore I would transfer my M.2 and 2.5" HDD from laptop to the new build and move the 250gb SSD from the Q6600 rig to the laptop. As the M.2 is too big, this now needs to stay in the laptop, and my wifes Samsung SSD will be used in my new build instead along with the 1TB HDD.
Now I need to figure out how to swap the data on the M.2 and Samsung SSD, is it possible to simply clone the data on each bootable drive between each other? Basically so they behave the same as before but the data on the other drive.
