Cloning HD and MBR - Help?
30 Apr 2007
Kent
Hi Guys
I have a low spec box running Windows XP Home Edition with SP1 with a 3Gb hard disc, yes 3!
I want to clone the HD so I can move it to a 20Gb Hard Disk and use the old 3Gb HD as a 'secret' share as I am turning it into a server. I have tried using a Paragon program and it said something about MBR, I believe this is the Master Boot Record. How do I copy this from the old HD?
I would have used Acronis but didn't have enough space on the HD and all programs on there are necessary as I cant find the disks!
Any help appreciated.
Try this link to MBRWiz.
I used it quite a while back. It may look a bit daunting but if you read the guidance notes carefully it should be ok.
If you get stuck post again.
Thanks. I am planning to sort them out tomorrow as I can't be bothered to face the task of dragging them out the loft today!
Thanks again!
