Things you will need
Macrium Reflect (free 30 day trial)
or
Paragon Migrate (paid)
or
Acronis True Image 2012 (paid)
Samsung Magician Tool (free/works with samsung ssd's)
A usb memory stick for the Parted Magic Secure Erasing Software,or burn to a cd and boot from it
Heres the guide to setup a bootable usb stick and how to use parted magic to secure erase your ssd
http://howto.cnet.com/8301-11310_39-20115106-285/how-to-securely-erase-an-ssd-drive/
http://partedmagic.com/
Ok down to cloning your operating system to your ssd(in my case i wanted to clone my ssd to a blank 120gb hdd/secure erase the ssd to restore lost performance and then clone back the operating system to the newly erased ssd)
Its the same process if your cloning from your hard drive to your new ssd just select the hdd first and the ssd as the target drive
software i used was Paragon Migrate,simply becuase im used to it but all cloning software will be similar,heres the process from start to finish in screenshot form
Remember to select the newly cloned ssd/hdd as first boot device in the drive boot order in the bios so that your pc will boot from it
or
or
