- 22 Apr 2008
I'm just building a new PC using a CM 690 case. Now that I have come to mount the PSU at the bottom of the case I am unsure as to the best way to orient it. It is a Corsair 620W with an exhaust outlet on the back and a 120mm inlet fan. The Coolermaster manual implies that it should be mounted so that the right way up ie. the big fan faces the outside of the bottom of the PC but I'm concerned that there is only a 15mm or so gap between the bottom of the PC and the carpet it will sit on. Is this OK for cooling or should the main fan face the inside of the case?
I hope this makes sense! In a nutshell, which way up should the PSU lie?
Cheers!
Cheers!
