I had put Noctua 140mm fan at the top (exhaust out) and Noctua 120mm fan at the rear (exhaust out) and Noctua D14 with Viper (two fans x 120mm as a push pull at the exhaust nearby rear fan)
Temp lots better now:
i7 920 d0 @ 4.20GHz 76C (1588rpm) after 20x linpack
Motherboard 35C
North Bridge 46C
GPU 54C
Room Temp 21C
But it not bad at all, but Antec 1200 case with all case fans is far the best air-cooling but it really annoying with noisy fans thought.
If you want cool then the HAF-x is the way to go on air. Outrageous amounts of air shifted and chilly temps. The cheap haf cases simply aren't as good.
