Cheers had the lip outside the casesquiffy said:You need to flip the mounting panel, and I think you put the mounting panel lip inside the case
Removed the 3.5" bay completely to make way for the removable caddies, didn't see any metal bits behind the 4in1, my cablings a mess anyway so that will impede the airflow more if anything.squiffy said:Oh I would remove the metal plates behind the 4-in-1 module (impede airflow) also remove fan guard from the module, you've got the mesh filters anyway. I've also removed fan guards from exhausts (inner and outer guards) and removed the top 8cm fan.
Moron said:how'd you get two 120m fans at the back surely there isn't room?
>>>>> goes to poke round the back of my stacker
squiffy said:The fan on the top panel is 8cm, but the two at the rear are 12cm.
squiffy said:ermm, PSU is at the bottom. The 810 no longer has dual PSU support (I think most people don't need them anyway) instead it has second exhaust fan. It would have been nice to have cover/cage where you can choose between extra fan, or top mounted PSU...but hey ho.
Moron said:mansize, i have the older one where u got a cage at the top for 2nd psu, can be converted to hold 2 80mm fans, so must be older model.
Mansize_tissue said:Aha, yeah that's what i though. Cheers. The motherboard tray on your case is removable, too, right?
How much are you willing to spend? A Silverstone TJ-07 would be perfect for your needs as it can take two 120.4 radiators without issue.Moron said:i'm thinking of selling my stacker, wnat a case that can take two 120.2 rads without serious modding. Thought about having one in the top and bottom (should be room) but not perticularly handy with cutting plus would cost the same to sell it and buy a case thats more expensive like the mozart or that cube ufo case.
