CM Test Bench V2
11 Dec 2012
Hey guys,
First post so hope this is in the right section :)
Background:
I entered the Cooler master mod competition this year and thought.
I was thinking for ages for a case to pick and by accident I found the test bench by Cooler Master at a local computer store. I knew instantly that this is the case I wanted to modify. It's different enough to other cases and I didn't find anyone else in the competition using the same case.
After countless hrs designing i think i came up with something worthwhile doing.
The original case
This was the design I stuck with for now unless i change my mind for a 100th time
Also started fabricating the radiator boxes today.
Started with some kinda straight pieces of 1mm sheet metal. Decided on 1mm thickness to add some stability and still easy to fabricate.
The machine
Bent a small test piece to figure out the radius and the measurement, also to get all the angles right.
Made four pieces so i can mess up two, easier to make extra now than going back to make two new ones :)
Quick test fit to see how its gonna look
Also some parts arrived :)
Back after a lot of hrs in the garage and at the workshop at work. Not much of an update when it's full of fail but thought i would share anyways.
Plan A
Cut a template of the size i wanted
Mark the piece to be cut
Working with my best friend :) (angle grinder)
After a lot of filing.
After this i realized cutting the next 3 slots in the metal will make it very thin and will flex and bend a lot. And the plan is to powder coat it after i'm done with it, so i can't use any filler. so over to...
Plan B
Decided to get all the cuts before bending. Don't mind the tolerances, just forgot to adjust the digits
Make a "table" for the mill at work.
Used double sided sticky tape between the table and the metal sheets to prevent the pieces to vibrate during milling.
Fastened the sheets with screws in as many places as possible, i did not want the sheet to move during milling.
Let the milling begin. Still a Manual mill so need to be very focused :)
More fasteners used as it progressed.
Almost done, still need to clean all the edges and as you can see in the red circle i made a bit of a mess. I had just finished that slot and turned the mill off without turning off the feed. So when i turned the mill on it went like a bat out of.... :( Words cannot describe the feeling when that happened. I had spent 6 hrs milling just to do a simple mistake. Anyways, gonna weld it back and see if i can file it down. Wouldn't be a problem if i could use filler.
welded and grinded down the mess i did the other day :)
Got the sheets bent today but now i don't know if i should go with the circular mesh or the hexx mesh. The hexx mesh is made out of 1mm aluminum and the circular mesh is made out of steel sheet which would make the whole construction a lot more stable.
Found another mesh today but not really liking it
Also tried some powder coating last night
This is satin black. Two problems with this color, fingerprints sticks instantly, and it looks kinda cheap
Gun metal gray. Had to try, not gonna paint it like this though
This is the surface finish of the original cooler master case. I'm really liking this surface finish so i'm gonna order some textured powder coating black and give it a try.
Gonna order this color and give it a go!
Got a lot done the last week so thought i would post a few pictures
First of all I'll show you something great when working with metal sheets. I have not seen many use these and i don't know why. They are quite handy when you don't want to weld and will help a lot in hard to reach places, when you don't have to use a regular nut. It's rivet nuts :)
Works like a normal rivet.
Modified a normal rivet gun buy cutting the head of a M4 bolt and jamming it in the rivet gun. Added a few washers to prevent the rivet from entering the gun
Screw the nut on the thread
All done
In the end I just got a rivet gun made for the rivet nuts which made it a lot easier.
Made some acrylic for the case. Had to countersink the acrylic in order to get it flush against the case
Mounted. It's clear acrylic but it has a green protective sheet on it.
Spot welded some ends on the radiator holders and mounted it all together
Removed the green protective plastic. Still needs to be sanded to get a matte finish so the red leds will spread the light better.
Drilled the front acrylic plate. Still need to remove a lot of acrylic in the middle
Drilled holes in the aluminum after i knew the acrylic would fit.
Test fit
During the test fit i marked around the edges with a knife so i could get a rough template.
As you can see its a bit rough :) Will still do some more welding on the case and when that is all done i will grind down the front and back plate and sand it smooth. But you can see its starting to look as the rendering :)
Sneak preview
Almost forgot to update, have another project that I've been working on for the last 5 months. Can anyone guess what it is? Just got the "table back from a workshop that leveled it for me. So now i just need to get it assembled and it should be good to go if I just can figure out how to use it :D
Back on topic
Started sanding the edges, tried a lot of different machines and files before getting the result i wanted. Still need to straighten up the edges but wanted to mill the fan controllers first in case i make a mistake and need to redo it.
Milled away a bit of material to get the psu as close as possible to the back of the case to make as much room as possible inside the case
Started disassembling the new lamptron's
Very easy to take apart
In the preview yday you saw the milling so no need to post more pics of that, the controller fitted!
Had to power it up :)
After looking for leds for the acrylic and realizing buying "computer leds" are way too expensive i started looking for other options. Found this through a company in Finland. I don't know the price but it should be less than 50€ for 5m of leds. These are 15,6W/m so should be plenty of lumens :)
The Leds can be cut every three leds and cables can be soldered on straight on the copper tabs, 8mm wide and 2,5mm high. The best thing with them is if you have a 2cm led strip or a 5m led strip all you need is 12V.
Also have milled the front acrylic, milled a 3mm gap to place the leds in, a nice tight fit.
From the top
Full 12V, probably need to run them on 8V, otherwise with 2m's of leds it will look like a nuclear power plant :D
As low as it goes.
Still need to sand the acrylic edges to make it more smooth and spread the light even better, but it's a good start.
Sponsored by:
Got some great news guys. After some discussions with EK Waterblocks they decided to sponsor me in this build!
Since I started water cooling I have always liked the design of the water blocks that EK provide. So it is truly an honor to work with such a great company!
The parts :)
Unpacked
This i won over at cooledpc.com but thought i would share it anyways
Pump top to add some performance
EK-DDC X-TOP CSQ - Acetal, such a buty
Waterblock for my Asus Gene-V, EK-MOSFET ASUS M5G
EK-CoolStream RAD XT (240)
A bunch of fittings, some i have bought and some sponsored
EK-RES X3 150
EK-FC5X0 GTX GW Backplate - Black
Special thanks to Gregor over at EK for helping me out!
Been quite busy the last few days having time off work in order to be able to finish the mod for the competition.
Started with some motherboard raisers, was gonna machine them in aluminum but then i found this nice red Ø20mm plastic bar. Not the right red but they won't be seen after its installed and it's so easy to machine in plastic.
First i machined them to the right diameter
Drill and tap
All done!
Test fitted the pumps and the rads to check for clearance issues
This looks a bit weird, but its in the middle of the case. Had to cut some space for the cables from the psu, this should be enough.
All sanded and ready to get glass blasted
Glass blasted and ready to be powdercoated
It looks a bit uneven but its smudges from me fingering it, i didn't see it but it shows up in the photos, will clean it off before the final shots!
Radiator box, or whatever you would call it
Rear side of the same part
Almost assembled
And some final shots of the case itself, I really like the way it looks and glass blasting the acrylic made a really matte finish which hopefully will hide the single leds and give an even light throughout the acrylic.
Still need to cut slots in some of the acrylic to be able to install all the leds.
Also need to make something to hold the GPU's in place, i know what i want now so I just have to fabricate it.
Finally decided to go with circular mesh, the hex mesh i got was only 1mm thick aluminum and was not stable enough. This is the color i went with, gun metal gray. Will make a slight contrast to the black powder coating.
For quite a while I've been thinking about what to do for GPU supports, I've seen a few versions out there but nothing that would fit my mod. The biggest problem has been production time of something more complicated that i would have to mill or grind from aluminum. So when I finished another project of mine (homebuilt CNC router) I decided to put it into its first good use (haven't had time to use it since all my time has been spent on the case).
This is what i wanted but wouldn't have had time to complete without the router. Test mount straight after milling all three parts.
Glass blasted and painted. Also countersunk one side and threaded M5 threads into the rear of the aluminum.
Close up of the support
Now you are probably wondering how i will physically attach the gpu's to the support. Haven't had time to see if it works but there is no reason this shouldn't. You mount it from the rear of the support so the tab from the GPU go between the support and the "extra bit" Then you just turn the screws to pinch the tab from the GPU to the support.
Also tried some engraving, my gf wasn't happy with the font, placement, size and basically everything, but I like it, It's about 0.5mm deep
Also covers a extra hole in the case, although this won't be visible when the motherboard is installed but still a nice touch :) Still needs a bit of filing to make it fit perfect.
Had to assemble the case in order to figure out where to drill holes in the mesh, so figured i would try to take a photo of the leds going at the same time, took around a 100photos before my gf snapped these two. It still doesn't show off the real red but it is awesome in my eyes :D This is as low as it goes, if i crank it up all the way u won't see the case. Gonna check with some ppl if there is a solution to get this right for the final shots.
Getting close to the end of the Coolermaster competition! Have been very busy the last weekend, spent around 30hrs on the computer on saturday and sunday and had to take today off work just to get it up and running. Taking it to get photographed tomorrow so i can get some proper shots of it for the competition.
Anyways, gonna start with the parts. A lot of the parts are from my previous build but there are also new parts
Coolermaster test bench
Intel 3570K
Asus Maximus GENE-V
Corsair Dominator Platinum 16GB 1600MHz
128gb OCZ Vertez 2 SSD
Corsair AX850 PSU
2 X Gainward GTX570
2 x Lamptron FC5 V2
4 x Schyte Gentle Typhoon
A lot of leds
Watercooling:
2 x EK-FC5X0 GTX GW Backplate - Black
2 x EK-RES X3 150
2 x EK-DDC X-TOP CSQ - Acetal
2 x EK-CoolStream RAD XT (240)
1 x EK-MOSFET ASUS M5G - Acetal + Nickel
1 x EK Supremacy cpu block
1 x EK Dual parallell sli block
2 x laing ddc pumps
A lot of EK fittings
Mayhem's Aurora tharsis red
Sleeved the led wires, the cat loves it
Installed in the acrylic
The lamptrons installed
Mounted the rads and the fans to an xspc rad mount, quite a tight fit, a little bit over 1mm to spare :)
Plumbing done on loop 1, was a bit more difficult than i first expected. Ignore the blue cables, resleeved them after
Had to check what it looked like with the Hyper212 that i've used during the build. Had to remove all the water cooling so i could get all the sizes right
So many cables, had to cut every cable and shorten them, they would not fit in the case as is.
Tried to get hold of some genuine CoolerMaster sticker but it was a lot harder than i expected. So contacted Coolermaster and got approved to make my own stickers. Was gonna go with normal stickers but due to the case is slightly textured it wouldn't look good so went with these polyurethane based "3D" stickers. Got a few different color combinations made so i could pick the one i liked the most. Big thanks to Mr Glasberg over at staffans.fi for making these priority 1 and making them in more or less a day
Assembled and more or less ready to go. Still have a lot to do but this will have to do for the competition.
Leak test ongoing
So here we go. As I'm looking through the pictures taken yesterday i realize i should have taken a lot more. Anyways, here are most of them without posting very similar looking ones. Enjoy!
Without leds on. Sadly a few fingerprints on it but better with them there than photoshopped away :)
Gpu loop
Leds on
Still have a few things to do with the computer but this will be it for the coolermaster mod competition. Wanna try to make my ram look like the gpu support with the same red glow. Not sure if its gonna work but gonna give it a go, also have some other ideas. But will have a week or two break now, need to sort out the rest of my life that has been left aside while building this.
Did a compilation photo of the mod for the competition so thought i would post it here aswell.
Sponsored by:
WOW that looks stunning. The mobo power cable in the first picture looks great if the GPU and mobo cables were done like that would look even more outstanding. Gratz superb stuff.
I'm stunned!!!
The amount of time and effort it must have taken and it looks perfect! Wish I was as creative and had the tools to make something like this.
Tidy, well made, colour co-ordinated......:D:D:D:D:D
absolutely beautiful matey, stunning build, id be tempted to wall mount it :D im way too clumsy to have an open pc
Impressive amount of work into that!
Looks great. :)
Thanks!
Thanks! Yeah, i don't like the cables either but i will do something to them as soon as i get some spare time. Had to get some pictures in for the cooler master mod competition, head over to their facebook page and vote for me if u have a spare min!
I'm stunned!!!
Thanks! Sanding the edges almost drove me insane :D
Best test rig I have ever seen built.
That is beautiful, I envy this!!
Thanks!
Love the two reservoirs looks so tidy, great work!
Thanks! Spent hrs moving them around before i found something that looked good. Glad i had these reservoirs with lots of ports :)
Incredible mod, I would love to have an open top rig like that, looks like your hard work certainly paid off!
Thanks!
Very impressive work there mate.
Thanks!
+1
Amazing work :cool:
Thanks!
lol, you are not the first to suggest a wall mount to me :) I am planning on a smoked acrylic cover for it, just need to design something that looks good. I have two cats and they are not well behaved :D
Great build mate! Truly class! Lot of hard work paid off!
Thanks!
Question: Can you only multi quote three post?
Stunning work. So much effort and attention to detail.
Can't wait to see what you do with the cables.
Personal preference, but I'd like to see transparent WC hose. No biggie though :)
Good luck with the comp. You deserve it after all that work.
Brilliant work, some real skills you have there, well done. :)
Thanks!
Thanks!
Thanks! Yeah, it was a hard decision between transparent and the braided hoses. Have started with the ram now so hopefully next week i will have pictures :)
