- 8 Feb 2004
- Dartford, Kent
I can hear the difference between the 3 different coax leads Ive got and the optical so it all depends on how good your ears are and the quality of your hifi.If you have cheap DVD player and av amp then a cheap lead from ******s is all you need.
The fact that you feel you can compare the coax & optical means the signal is obviously digital on both (obviously only the coax could be analogue).
If you can honestly tell the difference between the cables on a blind test then I would get down on my knees and suck your balls.
The fact that you can not tell the difference between "monster" cables and a coathanger (sauce: http://consumerist.com/362926/do-coat-hangers-sound-as-good-monster-cables) shows that any cable able to take a digital signal as long as it gets from A>B will sound fine.
If you can tell the difference, then I will bet money that it is a difference inside your system that is changing the signal between the outputs and that it is nothing to do with the cable.
So basically, you're talking turd.
It will not make a difference what cable you use, go and buy a cheap one and save your money
