COD 4 Level 55
23 Oct 2009
Derbyshire
Noon all,
Went on a friends Steam account to play some TF2, afterwards went on COD4 that both him and me have. I loaded up the game and it said something along the lines of 'All your stats and emblems have been re-set'. I though that was just on his account so I logged off his and went back to mine, got exactly the same thing.
Is there anyway to get to level 55 without playing continuously? I really don't have the patience and wouldn't have ever gone on his COD 4 account if I knew this would have happened. Is there any legit way of doing this so I don't get banned off servers, I basically just want my AK74u, UAV Jammer and Dead Silence back.
Thanks.
nope you will need to replay and rebuild it, on the same note I See I have lost all mine On Waw even tho I have saved them in a separate file when I try use them i the game just does see them :(
For **** sake...
I tried to save my other folder from XP as I reinstalled Win7 and got the same message, I assumed it was because i've gone from XP to 7.
Thanks anyway man :(
Oh just another quick question, is there any server that give ridiculous amounts of XP so say I get one kill it'll be like 100,000 XP?
Can't find the Activision folder anywhere though, using this video:
I'm guessing it'll be different as it's through Steam. Anyone care to help out?
Yeah i remeber using that hack back in the day after a fresh install, and seeing as theres no bulls**t IWNET, you wont get banned :p
I was on COD 6 level 33, I got my first kill of the game and everyone went straight to level 70 lol or whatever the top level is. I thought it would last the day but im still the top level 3 months later lol
You don't need to do it by registry. Just do it all in game.
1. Change the CD key
2. Replace the file
3. Join a server
4. Quit server and replace CD key with original
5. Join a server
6. Done
2. Replace the file
3. Join a server
5. Join a server
6. Done
Alright, here's what I did:
1. Started up COD4, changed the key to this one - DL2J8PY44Q22GE4888D2
2. Replaced the existing mpdata file with the one I downloaded from here.
3. Joined a server, it said the key code is already in use.
4. Replaced the above key with my genuine one.
5. Joined a server, still had only 3 pre-made classes and was level 1 0%.
I must be retarded here as i'm following the instructions as stated but it's still not working.
I have my server filter set to hardcore & mod and that's it. I'll try again later on, am I doing everything right though?
Thanks a lot Swifty.
Actually scratch that; I remembered it wrong...
2. Replace the file
3. Load game, should have rank 55 with all unlocks
4. Replace CD key with original
5. Join a server
6. Done
Still doesn't work... :(
Maybe they've patched it or something. Oh well never mind, i'll just start from scratch again.
God damn this game I tell thee.
ah this is not the hack I was thinking about, I was on about the one that gives you (well hoe ever muck XP you want per kill)
