COD2 best texture setting??
Jongo said:
u should b able to run it all at max..
Sorry didn't explain well enough, within graphic options it says texture filter setting it can be trilinear - Anisotropic - bilnear!!
Aorry lads missed the filter part off first question!! :(
edit: sorted
4) Filtering: Bilinear is the least appealing but fastest. Trilinear is better looking that bilinear but a very slight performance hit. Anisotropic is the best looking but is more of a performance hit. There's really no reason to use bilinear. Anisotropic is what you want if you can get it but it results in a medium sized hit for performance when you turn it on
Well if you want to use AF, force it via your graphics driver. If you don't just choose trilinear.
Edit: i always use AF, so i have it set to trilinear in game and 16xaf forced via ATi CP.
