Hi,
Just built my new rig recently, and I am very happy with it, except for COD4.. I was expecting it to be perfect... But unfortunately its not.. Even through my FPS are way over 60 with vsync off, there is some slight judder especially when moving the mouse sideways. Some maps worse than others. None perfectly smooth though. Typically I just leave vsync on but i did try a whole plethora of different settings and if the truth be known, its the smoothest with everything on right on the max 16x af, 4x aa.. vync on.. 1900 x 1200
I mean its not bad, but definately not perfect like most of my other titles.
Same deal when I've lowered all the settings to basic, the same slight judder is there, plus with my fps up over 60fps I can only assume its just the way it is? I've got this running on both Vista Ultimate SP1 and WinXP SP3 (both fresh builds as of this week) latest drivers for everything, but both O/S's are the same, everything patched upto 1.7.. Maybe cos I'm too use to it's super smooth constant 60fps on the consoles? I dunno.. But eitherway I am left a little disapointed..
Could it be my 4850drivers not up to scratch? Anyone else with a similar setup seeing the same as me? Or am i just being too fussy and i should stick to the smoother console versions... All my other titles run as smooth as a babies buttock.
