Code injection attacks using IE7 Beta 2 preview
Permabanned
15 Aug 2003
Ipswich
Hi,
I installed IE7 Beta 2 preview today and after about an hour my firewall (kerio) advised me that it had blocked an intrusion attempt under it's Host Intrusion Protection System section.
The affected application was IE7 and it was apparently a code injection attempt. This has never ever happened before so I have one or two questions...
1) Is it serious? I've gone back to IE6 for now, so perhaps it's just a security hole in IE7? It is only a beta preview after all.
2) what is code injection? I can take an educated guess, but wouldn't mind knowing whether this was as a result of an outside force, or something on my PC already, or just a flaw in IE7.
I'm using a NAT router and then have Kerio running as well, so I'm inclined to think it wasn't from the outside, but you never know!
Thanks in advance
Does sound a bit odd.
Code injection usually refers to someone managing to manipulate an input into software in order to execute arbitary code - for instance, a poorly written php script can sometimes allow a field on a webpage to be manipulated to execute code on the server.
Not sure what that has to do with your firewall or IE7!
