- 12 Jun 2011
- Near Overclockers
PC spec. added at end (thanks for pointing out that I missed this off)
Since getting a new PC (Windows 7) many of my video files stutter and stammer (so to speak), and don't play smoothly. Currently I have the Windows 7 Codec Pack installed, as well as the latest DivX. Generally, I use Media Player Classic or VLC Player. If anyone knows of a kind of miracle codec solution I would be forever indebted to them. Thanks for reading this post.
PC is a basic OcUK Titan with a few improvements inc. AMD Dual 3.00 GHz, 8.00 GB RAM (1600MHz), 2TB Hard Drive
My old PC did play all of these files fine, so I doubt it is the spec. - However, that machine went kaput, so I can't find out what I had on it (whatever it was that I don't have on this one)
Thanks for the responses so far - I'll get cracking on them
