- 18 Oct 2002
- London
I'm probably not the best person to ask, as I'm something of a coffee nazi,
however its like most things you get out what you put in, I have a separate grinder and although I got a good deal (mate of a mate)
the grinder at retail is circa 350-375 GBP
and the coffee machine at retail is circa 600 GBP
I wouldnt suggest going anywhere near that level to start
the most important thing for the coffee machine is to be able to maintain a consistent brew temperature, so that you can make every cup the same, then its about adjustments as to how you pack the basket etc.
for the grinder you are trying to have as much adjustability as possible so you can grind as fine or as coarse as you wish, consistently.
I would advise getting separate grinder and machine even if entry level, as then if you need to replace or upgrade you dont need to do the whole rig in one go.
Surely it would be even worse than a stove-top for espresso since you can't possibly get much pressure just by pressing down the top of it!
It's very good, only problem is it takes a while
