- 22 Feb 2014
yup the only fault code relates to engine running lean, which started happening after this issue.Have you checked for fault codes?
Have replaced a vacuum pipe which the garage thought would sort that, he said if it doesn't he would replace the MAF next.
My normal garage is going to sort out an exhaust leak end of next week, and if that doesn't cure the lean running, we will look at cleaning/replacing the MAF.
I don't think the lean running is in relation to the cold start issue, simply because it started happening afterwards and it happens wether on petrol or Gas.
