Anyone got any ideas as to whats up with this? I got my new Sabertooth 990fx R2.0 and swapped it all over and did a fresh install of windows 8.
If I boot my PC from a cold boot, after it's been switched off for a while, the first boot, the power will kick on smoothly, and all will be well, but no bios display or anything and my monitor stays in standby, but fan controller works properly. I hold the power button and shut it down manually. Then start the rig back up again and its fine. Normal boot and display.
I switched it off and left the mains on for a while and it booted ok but froze when I started firefox. Restarted it (reset button) and then works perfectly.
I can then run 3d mark, heaven, prime95 with no problems at all. Its got the latest bios (1903).
It will also all overclock ok (4.5ghz cpu) but the memory wont, stuck at 1600.
I can restart it and everything fine once its been on.
My setup is:
FX6300
Samsung greens 2 x 4gb
Samsung 830 128gb
MSI 7970 TF3 oc be
XFX850w pro
My setup is:
FX6300
Samsung 830 128gb
MSI 7970 TF3 oc be
XFX850w pro
