Combining 2 PC's into 1 PC, help please
28 Aug 2006
Hexham
Further to my thread here about building a new rig, I'd like some advice on getting everything working properly - http://forums.overclockers.co.uk/showthread.php?t=18053398
I've bought a Q9450 instead of doing a full upgrade, so it should be fine for my PC usage and the wife's TV usage.
Can I control the PC normally with my keyboard and mouse on one screen whilst she controls the movies with a wireless keyboard on another screen?
I'll have 3 HDD's to fit into a HTPC case that only accepts 2 HDD's, can someone please recommend me a 3.5" external ESATA caddy?
I'm also going to have 2 DVD-RW drives and only 1 5.25" bay to fit them in, so again, can someone recommend me an external 5.25" caddy, preferably ESATA again?
Sorry for the stupid questions and poor grammar, it's too early, ha ha! :p
Pretty sure that's a no... at least not by default. Anything typed on one keyboard is going to register as typed by the other.
You could however try something like a simple media remote controller (i.e. there are no keys to press, just buttons for play, pause, next, etc). Only one at OCUK seems to be http://www.overclockers.co.uk/showproduct.php?prodid=GX-012-CP
Alternatively, you could invest in some multi-user software for the PC, allowing you to have concurrent logins on different monitors. I think google's your best bet there: http://www.google.co.uk/search?q=multi+user+pc+software . Some potentially promising options, but it's just a realm I've heard of, rather than had experience in ^^;
Good luck!
It's not that tricky to do under linux at least. If you run a separate X session on each screen, you can dedicate a keyboard and mouse to the second screen. There are various phrases to Google, multihead/multi-head is probably the most useful one.
I set up the dedicated keyboard a while ago, had one machine running ubuntu with xp in virtualbox on the second screen. Works really nicely, but you might not want to switch to linux.
I like the akasa enclosures for hard drives. They work with cd drives, but obviously the cd drive doesn't fit in the enclosure. So it's messy running cables between the drive, enclosure and computer. Do you need two optical drives? If one has a film in, you could use an iso file of your disk with demon tools instead?
Fun thing to set up, enjoy :)
I have an LG HD-DVD/Blu-Ray drive for movies, and a Pioneer 216 for burning, as the LG's very poor in this department, so 2 drives will be a necessity unfortunately.
I'd like to keep running Windows 7 if possible, not sure how Linux is with HD movies and surround sound?
Good point, well made. Linux isn't so hot on sound card drivers, though vlc works just the same on any platform.
I wish you luck then, so far I've not persuaded windows to run two displays independently. I hope you post back when you find a solution :)
