** COMING SOON - BITFENIX RECON WHITE **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Due to popular demand, we have available for pre order, the Bitfenix Recon in white!
perfect for Shinobi and prodigy cases in white or any of the multitude of white cases on the market today, the Recon is a brilliant fan controller packed with unique and exciting features!
BitFenix Recon Internet-Connected Fan Controller (White) @ £28.99 inc VAT
Take control of your system anywhere with the BitFenix Recon™ Fan Controller. This five channel fan controller features internet connectivity - another world first from the BitFenix Design Labs. Featuring dual processors that continuously interact with your motherboard, Recon enables you to monitor and control your system on the go with any internet-connected device, including the latest smartphone, tablet or laptop. The easy-to-use touchscreen displays your current system temperatures and status, while giving you easy access to Recon's robust functionality. Customizable profiles make it easy to save and recall your favorite settings, while the SofTouch™ bezel makes it an attractive addition to your killer rig.
- Internet Connected for Mobile Devices
- Touchscreen Controls
- Dual Processor Technology
- System Status Monitoring
- Five Channel Thermal Control
- Customizable Profiles
- BitFenix SofTouch™ Bezel
- Materials: SofTouch™, ABS Plastic, Steel
- Dimensions (WxHxD): 147 x 43 x 67mm
- Form Factor: 5.25" Drive Bay
- Fan Channels: x 5
- Temperature Channels: x 5
- Max Watts / Channel: 10W
- Measurement Frequency: Every 0.1 – 0.4 Seconds
- Temperature Alarm Range: 30 degrees - 90 dgrees
- Temperature Range: 0-100 degrees
- Screen Size: 4.7"
Only £28.99 inc VAT.
PRE ORDER NOW
Ive got the black one very good unit if a little temperamental when the probes get a little too cold
depends on your setup, in my 810 ive got 2 cpu fans 2 140 case fans 3 140 top case fans and 1 more 140 back and bottom all of which are 3 pin. With all these running at full tilt it gets loud, this unit allows me to run them at varied speeds either manually or automatically
yeh ive got 2 * 200mm fans ontop, 2 120mm fans on the side, 1 120mm fan on rear 120 radiator, 1 * 140mm intake fan on the front, 3 * 120mm fans on 360mm rad.
i might get 1 then as like you say gets loud when there all on full
Are these only able to auto-control fans based on probe temps or can you use system temps?
Looks great in white, if they can detect system temps I'll definitely be putting one into my Phantom.
Are they compatible with the BitFenix Colossus Windowed's 230mm fans, which in my experience haven't worked with controllers that require three-pin fan connections (even though they are 3-wire fans)?
