Hi Guys
Coming soon we have this excellent case from Silverstone.
Following on from the Raven success in the past, this console replacement chassis is perfect for your gaming PC in the living room.
You certainly will not be running out of STEAM when you are thinking outside the BOX with this chassis.
Silverstone SST-RVZ01 Raven Mini-ITX - Black @ £49.99 inc VAT
Since the debut of the original RAVEN RV01 in 2008, the RAVEN team demonstrated at Silverstone many times as it can truly define and meet the expectations of computer enthusiasts with regard to the capabilities of a powerful PC in form and function. For 2014, the team set a new objective: Exceeding and transformation of the SFF (Small Form Factor) Landscape with another groundbreaking housing design. The result of this effort is a new range of housing products named RAVEN Z. The first model, the RVZ01 lifts completely from all previous small form factor case from Silverstone from. Thanks a PCIe riser and custom fan, this slim 14-liter enclosure accommodate the largest graphics cards on the consumer market - with excellent air cooling and the ability to support liquid cooling solutions *. Designed for use in both vertical and horizontal orientation, it can be easily set up at all cramped places where a powerful PC is needed. Who would want to change with the help of a truly remarkable housing on computers with small form factor, struck gold with the RVZ01.
Specification:
- Characteristically RAVEN-style
- Supports graphics cards up to 33cm
- Mini-ITX motherboard, power supply SFX-enabled
- Maximum performance in slim form factor with support for liquid cooling
- Pressure design for excellent cooling, low noise and preventing dust formation
- Fits in nearly any environment with horizontal or vertical orientation
- Material: Plastic outer housing and steel frame
- Colorblack: MotherboardDTX , Mini-ITXDrive bays
- External: Slim optical slot-in drive x 1
- lntemal: 3.5 "x 1, 2.5" x 3
- Cooling: Cover1 x 120 mm fan, 1500rpm, 18dBABottom1 x 120 mm fan, 1500rpm, 18dBA 1 x 120 mm
- Slots: 2
- Front connectors: USB 3.0 x 2 audio x 1 MIC x 1
- Power Supply: SFX
- Graphics Cards: Compatible with 13 "long expansion cards, broad restriction - 5.88", width restriction
- Limitation of CPU cooler: 83mmNet Weight3.71kg
- Dimensions: 382mm (W) x 105mm (H) x 350mm (D), 14 liters.
- Extra: Supports Kensington Lock
Only £49.99 inc VAT - PRE-ORDER ONLY PRICE!!
ORDER NOW
Specification:
- Slots: 2
- Power Supply: SFX
ORDER NOW
