Command and Conquer RA2 problems? Help plz!
22 Dec 2002
Minehead
Hi all,
My friends just got the above game from an online book place and installed it. However every game you start it just kills you about two seconds into the game. I seem to remember this being a problem with certain dvd drives or something to do with the copy protection?
Can anyone help? Cheers :)
Are all your buildings just exploding? If so, then yes I believe its a copy protection issue. Try reinstalling and make sure you use different codes? Or you could try a no-cd patch.
