Command n Conquer keeps crashing :(
25 Nov 2009
Hi chaps,
When trying to start any game in C+C 4 I just get this. It is a fresh install on win8.
Has anybody got a fix?!
Much appreciated:)
EA lol..
I remember when tiberium wars 2 or whatever it was game out and they had a 50+ page thread about the game crashing on the forums but EA never cared enough to investigate it ......
Right click on the game icon, change compatibility in the little drop down box to Windows xp etc
On the mac so i can't screenshot where or how it looks mate.
Have you tried searching for a fix using Google? I know a few of the C+C games have compatibly issues with Windows 7, so will be the same for Windows 8.
I don't think I'm with you...
I'll do that now.
go into your desktop and find the app, then right click and properties.
Ill get to the PC now for you mate.
Edit: Very bad photo haha.
To do either of these, begin by navigating to the game's directory on your hard drive (most likely Computer>C:\>Program Files>Steam>steamapps>common>Command and Conquer Tiberian Twilight).
Once there, to launch the game, find the Command & Conquer Tiberian Twilight Application (be sure you've located the "Application" and not the "Icon" filetype) and simply double-click. This should run the game independtly from Steam. To attempt to run the game in Compatibility Mode, right click on your C&CTT Application and select either "Run in Compatibility Mode" or choose from the available compatibility options (depending on your operating system version).
You want to right click the CNC4 file which has the type Application. Then click properties, then you should have a Compatibility tab.
