Comment on my build please
13 Sep 2013
Hi,
I am planning to buy a computer for working on all sort of development including SharePoint 2013 (alone requires 32GB ram) and for playing games occasionally too, so my needs are,
  1. 64 GB of Ram for development
  2. single video card using which I can play most games at normal settings (Not into FPS but I want a normal good looking graphics and game shoudn't lag at all)e.g. GTA V when it will come out
  3. Silent PC as I live in a shared flat and don't want to disturb other's
  4. Future proof
I have been doing research for last 3 - 4 months but still not satisfied by my build, so need advise please, Here are the items I am planning to buy so far,
Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K)
Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard
Kingston HyperX Beast 64GB (8x8GB) PC3-14900C10 1866MHz Dual Channel Kit (KHX18C10AT3K8/64)
Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW)
Corsair Hydro H100i High Performance Liquid CPU Cooler
Corsair Builder Series CX 750W Modular '80 Plus Bronze' Power Supply
Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
Fractal Design Define R4 PC Case - Black/Pearl
Please comment where I can improve and whether should i wait for Asus x79 - Deluxe to come out and buy that one or not.
Also Should i wait a month or so to get cheap deals e.g. near december ?
Thanks
Nice start, but made some adjustments:
YOUR BASKET
1 x Kingston HyperX Beast 64GB (8x8GB) PC3-17100C11 2133MHz Dual Channel Kit (KHX21C11T3FK8/64X) £479.99
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £254.99
1 x Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard £239.99
1 x Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £229.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) £99.95
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £50.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £1,653.85 (includes shipping : FREE).
SSD is newer and quicker than the 840 Pro series, cheaper too
Corsair RM is Gold Rated & Fully Modular for roughly the same price
Sp120's to replace the stock H100i fans, will be quieter & more efficient
Not sure you'll need 64gb RAM, 32gb would be fine, but it's your choice.
I'd remove the link to Amazon before a MOD finds it, you cannot link to competitors.
SP13 doesn't require 32GB RAM!
If you want to work smoothly on it then off course it does, I want to try like 10 virtual machines together, along with server 2012, sql 2012, project server etc all virtualized so I believe I need this ram, I probably will get more disks and add Raid to it but not at the moment. so size of ram is out of question as I have done my homework on it and can afford it to :)
Depending on the environment it's being setup in, yes it does. The SP server requires 16gb, the SQL server required 8-16gb and that is just 1 setup. If he is running multiple VM's, SP servers and his own desktop, it would easily consume close to 64gb.
But that's not what he originally said, was it. The original comment was SP requires 32GB RAM when it doesn't.
If you are including a whole host of VM's then of course you need plenty of RAM but the original comment in isolation is incorrect.
