Looks like nvidia driver related. Try uninstalling it and downloaded the latest driver?
The driver "folders" are fine, thats where the installer extracts them to, then uses a file within the folder to install the driver. You can actually delete the NVIDIA folder from there as the files are no longer required once installed. I dont know what else could be the problem. Does the problem occur when your not using SLi?
