I don't know if this is right place for this forum but i need help. I have just bought all my computer parts on here on friday, then i when i got them i went to work installing them. when i have finished it was booting up fine then when i went to try and play a game it crashed. after my computer doing this 5 times windows offered me a solution, i might be the RAM. so i downloaded the program they gave to test my RAM and when it started the test the RAM was failing.
So i went around some forums looking for a solution, one told me to try each RAM stick on its own, which i did and they worked OK on there own. so i have been running my new computer on 1GB instead of 2.
Yesterday i went out and bought STALKER when i try and play this game after about 1hour it crashes again, and again windows is telling me it is the RAM.
Has anyone any idea how i can fix this???
Thanks in advance
PC SPEC;
CPU: e6600 duo
MoBo: Asus P5N-E SLI
Graphic: BFG 8800 GTS OC 320MB
RAM: Corsair 2GB DDR2 XMS2-6400 C4
PSU: Corsair HX 520W ATX2.2 SLI
Thanks in advance
PC SPEC;
CPU: e6600 duo
