comp problem
26 Dec 2009
belfast
my comp keeps crashing every couple of weeks or so, which requires me to take out 1 of my ram and recently i've had 2 use the built in bois back up to get it to run again. once i get it running again im able to put the ram back and restore the OC profile.
i thought it was something wrong with my OC profile but when i reclock it to the level it was and run prime 95 for couple hours i get no crashes. i then use it again for another couple of weeks and it crashes again, and again i check the OC for a couple hours and nothing happens.
i'm not sure what the problem is so was wondering if anyone has any ideas?
current specs:
Intel Core 2 Quad Q8200@ 2.55GHZ
4x1GB DDR2 RAM 800mhz(cpu-z says its running at 364.9)
Asus P5Q Deluxe
9800gtx+
650W coolermaster PSU
First of all see how things run without the OC i.e. stock setting and see how you go with that.
Next check your is your PSU is functioning as expected. Use my guide here:
http://www.huddysworld.co.uk/index....rking&catid=40:techie-talk-hardware&Itemid=72
If your PSU is ok, then check your RAM modules by using MEMTEST86+.
Check the manufacturers website for recommended voltage and timings etc.
Try running your system with one stick of RAM at a time and try that stick in different slots. If the RAM stick fails in all slots, then its almost certainly a RAM problem. If the working RAM stick works in one slot but not another, then this is looking at a memory controller problem. This could be CPU or Motherboard depending on the platform.
Lastly, look at the system dump and Event Manager for clues. Event manager is often overlooked and under estimated.
It's a case of process of elimination but run all your tests back at stock.
ok ive set it at stock settings now, ill run prime95 soon to check it.
tbh im not sure about the psu. i had to increase the north bridge volatage so i cud run 4x1GB ram, but i think this is a limitation when using 4 ram sticks?
also have another problem but not sure if its the psu. My system is plugged into a surge protector and if i turn it off and on, then turn computer on its powers up for 1/2secs, doesnt boot thou, then powers off then 2/3secs laters it powers on and boots.
i dont thnk its the ram ive ran prime95 for 4hrs and it didnt crash or give any errors, its only seems 2 crash when im playing a game or/and when i play itunes
i checked event viewer and im getting kennel-PnP warnings and Bonjour Errors and the kennel-PnP warnings are linked to the Bonjour errors
Well the only way to know for sure is to test the PSU as per my article to eliminate that from the equation. I'm not sure why you had to increase the NB to run the memory at stock? If anything you would have to increase the VDIM. The NB only needs increasing if the bus speed is significantly increased?? Maybe you needed a BIOS update. Try running with only one stick of RAM, test, then add another then test and so on.
We can't give you an answer outright to solve your problem, we can only give you pointers to help isolate the problem which requires some work to eliminate the possibilities.
meant to post this last night><
i read your guide for the psu but many of the points where not required as my comp runs for hours using prime95 to stress it, and the voltages seem to be all in range.
about the NB voltage, i was told to up the voltage in a previous post to solve the issue but i think its at default now since i reset bios back to default.
Could it be a gfx card issue, since it only crashes when i have a game up, even though ive had games running on it since the last crash with no issues
