compatibility issue
10 Nov 2007
Southampton
hi
i recently recieved a very generous gift of an icy box
http://www.overclockers.co.uk/showproduct.php?prodid=HD-004-BT&groupid=701&catid=14&subcat=72
here is a look of the rear of the caddie scrool down a bit to see the views
http://www.raidsonic.de/en/pages/products/external_cases.php?we_objectID=2549
i noticed it had a sata data connection on the back and was wondering if i could use this product
http://www.overclockers.co.uk/showproduct.php?prodid=HD-002-AK&groupid=701&catid=48&subcat=
to transfer the data
thanks in advance
PCDave
Not sure exactly what the Akasa thing you linked to is for, it seems to route SATA power and data to a 3.5" bay and it's difficult to tell what cables are required. The IcyBox is powered externally with a brick so you only need eSATA - this is a simpler version of what you linked to and will work fine.
If you don't already have one you'll need an eSATA - eSATA cable to connect the IcyBox to that bracket.
