- 3 Jan 2010
Thinking of getting either a titan raptor or having this set up. Just a few questions I need to ask.
Firstly would I need any extra cooling fans (additional to what the case comes with)?
Would the power supply be okay to run all this? I'd consider overclocking down the line so would that need any extra power or is 650w okay for these parts overclocked (if I did overclock it would be very minor, no more than 10%)?
Lastly is the motherboard suitable for this kind of setup or would there be a better one you could recommend?
Mostly just worried I wouldn't keep it cool enough and it would overheat but I'm not planning on overclocking it much, Thanks for any help.
Case - NZXT Gamma Mid-Tower Case - Black
Processor - intel core i5 750 (2.66ghz)
Graphics Card - Sapphire ATI Radeon HD 5870
Hard Drive - Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) [HD502HJ]
Memory - OCZ Obsidian 8GB (4x2GB) DDR3 PC3-12800C9 Dual Channel (OCZ3OB1600LV4GK) [OCZ3OB1600LV4GK]
Motherboard - ???
Optical Drive - Samsung SH-S222L/RSMN 22x DVD±RW IDE Lightscribe ReWriter Drive (Black/Silver/Beige) - Retail
Power Supply - Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK) [CMPSU-750TXUK]
Processor Cooler - Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) X1
Sound Card High Definition 7.1 OnBoard Sound Card
TOTAL COST - £840 (without mother board)
Motherboard - ???
