compatibility question
16 Mar 2006
Telford
So i'm putting together a computer for my dad and have chosen all the pieces .
Just wondered if anyone would mind checking over the list incase there would be any issues.
  • Intel Core 2 Quad Q6600
  • P5KPL-SE, PCI-E(x16) DDR2 800/677, SATA 1.5/3 ATX (Heard these are good for overclocking)
  • Coolermaster Elite 330 + CM eXtreme PSU 650W
  • 1GB 9400 GT, PCI-E 2.0 (x16)
Thanks :D
Should be fine. Psu is way overkill though. A quality 400w would be more than enough. I doubt if the rig will pull more than 200w peak.
Thanks for the fast reply, Yea I was lookin at my own PSU last night and it only has 500w and its a similar setup so i'll probably change that.
Thanks
So i've decided to go with:
  • Coolermaster RC 330
  • 400W FSP Blue storm II
Would there still be enough power to play with overclocking?
Those FSP/OCZ psu's are not very good as they have high ripple (not good). Check out the new Enermax Modu 82+ (modular) or Pro 82+ (not modular) psu's. They are excellent and reasonably priced. OCUK does'nt sell them but they are widely available from £45 for the 425w version. There is a 385w version of the Pro 82+ for £38 that you could more than likely get away with. I have one of these in my second pc and it is very quiet and efficient.
