Compatible Wireless USB Adapter for Vista
21 Feb 2006
Southampton, UK
Hi guys, i'm having a little trouble getting hold of a compatible wireless USB adapter to run in vista.
At the moment i have a BT voyager 1055 adapter, which BT say they are releasing drivers for 'soon'
I have now just tried a Netgear WG112 adapter, and cannot get the drivers to install either.
So does anyone have a working adapter?
thanks.
got a netgear wg111t usb dongle thing working on vista
all i did was to tell vista to get drivers from the cd... think it used the xp ones :confused:
anyway works fine :)
edit:tis 32 bit
If it’s for a Laptop I can recommend a PCMCIA adapter the Buffalo WLI-CB-G54S 125* High Speed Mode Wireless Cardbus Adapter with AOSS, is automatically picked up in Vista no drivers needed.
