Complete Lock-Ups.
22 Dec 2004
Rugeley, Staffs
Okay Guys heres the deal:
I have a Gaming PC from a certain Irish Group:
Intel Q8300 @ 2.5ghz
4gb DDR2
Nvidia GTS 240
Windows 7 Ultimate (Fully Updated) along with all my Drivers.
The only alteration i've made to the system is a Wifi card which I fitted.
I'm experiencing intermittant freezes where it completley locks up (No movement of mouse etc etc) and no BSOD, I go back into the Event Viewer and it's only recording an Error in the Unexpected shutdown..
It seems to happen when i'm running EVE Online (Which has it's own logging software which i'm gonna run every time I start now.. but is there anything else I can look for that will explain these bizzare lock-ups?
As you said you recently fitted a wifi card, did you disturb any components when it went in? I'd just check all power cables and make sure everything is where it should be in the case.
So it was crashing before you put wifi card in?
Yup.
It isn't happening at any specific time either.. for instance today i've been running EVE for at least 6 or so hours but it also happens when I first start the PC (Within an hour or so) and then go days without a problem..
So is there a possibility it could be a Tempreture related problem?
Possible, Your pc nice and clean inside? or dusty if the latter i recommend a can of compressed air and give it a good clean inside and that may be your problem, What temps you getting at the moment?
Does it work fine without the wifi card in?
Holly Thread recovery batman.
The problem has started getting more frequent now, i'm running the Irish own Diagnostic program. It cropped up again playing BF2/STO
It's thrown up various errors on the HDD telling me it's pretty much toast and needs replacing.. now I have a hardware warranty with them still.. is this likley to be the cause of the hangs?
I'm having similar errors at the moment, using a different hard drive appears to have solved it. Nearly 36 hours crash free so far....
It's an IDE 40gb hard drive though. Lots of noise, and incredibly slow. Nice.
Sounds like your problems are hard drive related to me.
