I've got the PC mentioned in my sig and want to upgrade it, keeping whatevers viable and using whats left over as a basic for a media PC at a later date. Slight problem: I've not got a clue where to start, and for some unknown reason my PC doesn't like the OCUK forums and takes 30 odd seconds to load a page - so leeching off the advice given to others isn't particularly practical.
I'm looking to use it for gaming and browsing only, have a Thermaltake Tsunami Dream case (which from previous posts I believe should be re-usable?) and I've got a budget of £400 (can stretch to £500 tops, but has to be worth the extra) and whilst I'm capable of putting stuff together I don't know whats compatible with what, the last time I did any series digging I was told AGP was a dead end option - so you've some idea how out of date my knowledge is.
Its a big ask but could someone give some help putting together a build?
