Microsoft Windows 7 Home Premium - Retail (Full Version)(GFC-00025) -
make sure you get the 64 bit version.
32 bit will only recognise 3 gb ram as far as i know. (correct me if i'm wrong guys)
Cheers.
Out of interest, will the 460 work in my current setup? If so I might order that a little early.
If you aren't overclocking then there will be no need for additional cooling.
You could by the GTX460 now, and it would work, but as mentioned would be bottlenecked severely (basically, heavily reduced performance).
I'd have patience, and hold out until you can buy it in one lump.
Probably be cheaper that way I guess.
As for the RAM, I'll be using the old stuff in an HTPC.
Right, the HDD and RAM have arrived and the rest of it should be arriving next week.
Rather embarrassing question on a PC forum, but I've only once tried to plug in a CPU - years ago and it didn't work. Is there anything I need (some sort of paste?) and does anyone have a link to a decent guide?
Dont get paste anywhere near the CPU socket or it's contacts. The CPU just sits in there then is locked down by the cover. The paste is for when you fit the cooler to the top of the CPU. You knew that anyway, right? Just being safe
. Lots of vids on youtube. You want the 'pea' or 'line' methods if I recall - dont pre-spread with a credit card.I may be stating the obvious to you - but the paste aint for plugging in the CPU!Dont get paste anywhere near the CPU socket or it's contacts. The CPU just sits in there then is locked down by the cover. The paste is for when you fit the cooler to the top of the CPU. You knew that anyway, right? Just being safe
One up from 460 would be 470 or 6870.
, will my current 9500GT work with the rest of the setup?
