Complete noob - first PC build! Help!
23 Aug 2013
Hello! I've been a long time console gamer, but I've finally seen the light and decided to get myself a gaming PC! I'm 16 and still in school, so don't have the best budget, but its not bad! I've got £800 - 900 to spend on the PC itself.
I plan to better my PC as I go on, so I'd like a good base... So, preferably haswell! I'd like an intel i5 4670K £185, a good motherboard £165, (I've been looking at the asus maximus VI hero, I think that's good, correct me if I'm wrong! I don't really mind what mobo I have, as long as its z87, and its good :P ) And a nice case, black preferably. But I'm more bothered about it having good fan locations and cable management! I'd like to spend less than £75 on this.
After the case, MoBo and CPU Ive suggested, we're left with around £450 for the rest of the computer (ill buy peripherals and monitors separately, don't worry about them), unless you'd recommend different motherboards, or a cheaper case!
At the very least, I'd like a gtx 660ti for the graphics card. I plan to run 2 monitors, and play quite a few games on max setting/good fps, but I'm no pro, so, as long as its good, suggest whatever!
So, I don't think I've missed anything.... Ooh yes, I'd like room in my power supply to upgrade lots of parts when I can afford it, so I don't want to skimp on that either...
I know I'm asking a lot, but I'd really love some good advice on what I should do! I would like a SSD if the budget allows, and at least 1 tb of storage, as the PC won't just be used for gaming, I'll have to use it for a lot of school work too! Nothing too big though, lots and lots of word documents and power points!!
I don't think I've missed anything, but if I have, just let me know and I'll try and answer it!!
Thanks in advance! :')
