Component Temps
5 Sep 2017
Essex
Hi fellas.
I’ll running a i7-7700K (as standard)
Asus X270E Gaming MB
Gainward GTX 1080Ti
570X case
Fractal Design S36 Cooling system CPU only
I have Corsair Link installed because I have Commander Pro and fans are Corsair.
What’s normal temp for CPU under load (BF 1)
What normal temp for GPU ?
My GPU fan never seems to be running, do they set the fan to kick in a a given temp ?
I keep coming out of game to check I’m not cooking my components :)
Any help appreciated
xl...out
Download Furmark and check for yourself. Running furmark for 5 mins gives me GPU temps of 62 degrees centigrade with the fans blowing at 65%. That's a GTX1080 at 1440p and is well within acceptable range.
CPU tests using the same app show temps of 80 degrees centigrade after 5 mins (checked with HWMonitor) - again, acceptable temps with a 7700K @ 4.8ghz. This is on air cooling by the way.
What are you using to monitor temps? I've been a fan of HWmonitor for awhile now, but there are plenty of options. Let us know what temp's you're getting. I wouldn't worry too much with no symptoms really
Help .... Does anyone know what TMPIN4 is ???? I don’t think it’s supposed to be that warm, looks to me like it’s closed down or burnt itself out ??? Someone HELP !!!
xl...out
